Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-05-2013, 09:32 AM   #1
jmcleek
jmcleek's Avatar
Mig welder probem
I have had my welder for 7-8 years now and I think it is time to clean the little wheels that feed the wire. what / how are the rest of you using to do this.?
jmcleek is offline   Reply With Quote
Old 10-05-2013, 10:56 AM   #2
donut
donut's Avatar
Re: Mig welder probem
Little wheels? Do you mean the drive wheels? (steel, grooved)
If so, they should be removable. You swap different wheels with different size grooves if the wire size changes. I used to clean out the entire machine whenever I changed out a wire spool. (more or less) I used brake clean and a rag on these wheels, pop them out, swab them down, re-install or change depending on the wire. Rest of the machine, just a little compressed air and maybe a rag if big gunky spots present.
If I'm off base, post up a pic.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-05-2013, 11:07 AM   #3
jmcleek
jmcleek's Avatar
Smile Re: Mig welder probem
Thanks that is what I was looking for.
Old 10-06-2013, 12:47 AM   #4
dieseldawg142
dieseldawg142's Avatar
do you run a wiper on your wire? gets most of the oil off so it & dust dont gunk up the wheels
dieseldawg142 is offline   Reply With Quote
Old 10-06-2013, 06:56 AM   #5
jmcleek
jmcleek's Avatar
no ,would a supply shop have one or is this something I would have to make?
Old 10-06-2013, 09:50 AM   #6
donut
donut's Avatar
Supply shop should have them, if I'm thinking correctly, they're just a felt pad with a spring clip around them that goes over the wire.
This is what I was thinking of, http://www.weldaid.com/products/lube-matic-overview/
Old 10-06-2013, 11:37 AM   #7
ssapach
ssapach's Avatar
For a wire cleaner, I just stab the wire through an earplug. It's not the greatest or most high quality cleaner for a mig welder, but it keeps the majority of the dust off the wire and thus out of the wheels and liner in the cable.
And earplugs are usually cheap or free anyways.
ssapach is offline   Reply With Quote
Old 10-06-2013, 12:50 PM   #8
cableguy0
Also spray compressed air through the gun and liner itself. The wire scraping against the steel liner tends to leave residue over time. If you get it all out and cleaned up everything will run a lot smoother. Also make sure your tip is clean or just put in a new one. 30 minutes of cleaning can make a huge difference in how smooth the welder works.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-12-2013, 08:36 AM   #9
FarmerSid
FarmerSid's Avatar
I just wrap a piece of fine scotch bright pad around the wire between the spool and drive wheels. It is held on with a large black paper clip type thing.
FarmerSid is offline   Reply With Quote
Old 10-12-2013, 06:06 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have always run a wiper to keeps junk out of the liner that eventually builds up and get on the wire as it goes through. If you have an 8 year old welder it time to change the liner and wheels. Scotch brite, cloth held on with a clothespin. Anything that keeps the junk off the wire will work.
dwcsr is offline   Reply With Quote
Old 10-14-2013, 01:43 PM   #11
jmcleek
jmcleek's Avatar
I have cleaned every thing as you have said to, and have added a wiper/ luber to clean the wire and changed the tip. It workes alot better. My daughter is useing it now to learn on an work on a prodject for class.
