A beauty on eBay
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
![]() Join Date: Aug 2012
Re: A beauty on eBay
A beauty indeed. These trucks are works of art, and this one is no exception!
A very nice truck indeed.
I should post a photo of our patio roof.
We chose metal covered OSB and it is trash after six years of weather.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
I read composite deck which is what Orge used.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Over OSB. There is a photo showing it.
It is indeed a nice truck but the osb under the bed rather than putting in the cross rails an doing it right tell me that more corners may have been cut while applying a lot of effort to get the "look" just right.
It is going to be a bit pricey to consider buying it and doing the things to make it perfect though such as changing the bed floor for hardwood and stainless rails and swapping that way too flashy for the truck steering wheel for one that matches the rest of the appearance of the truck. The wheel looks great but it belongs in a full bling bling billet laden truck witha really tricked out interior while that truck needs a simple steering wheel , maybe one of the design it yourself ones from Con2R
Yeah..... No I think that would have to go.
58 Apache short fleetside ona 64 chassis: ![]() |
could not open pics on my phone. osb is not intended to be exposed, quick and dirty makes you wonder about the rest.
Note also the crappy welds on the exhaust hangars and the leaf spring u-bolts that are 3" too long. If you look closely, one of the pics shows the bed being raised about 8", up to the letters on the tailgate. Also, most of the fuel line looks like it's rubber instead of steel. There's a burn mark on the OSB from where the exhaust is too close. The bed looks like TimberTech composite decking. I'd be wary of this one.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#11 | |
All the welds on that exhaust look torch welded. I sure don't like raised beds on these trucks. Ruins it for me. |
Now that I look at it again, I think you're right. The burn mark would have been all along the pipe. I just don't know what to say about building a truck that looks as good as this one does on the outside, then not take care when wielding the torch. I suppose the local Midas guy didn't have as much pride in his work.
#13 |
Run Forrest run!
#14 |
Probably won't make the reserve.
#15 |
That was probably the guy at the muffler shop who scorched the bottom side of the bed a bit. It looks like they weld up in about the same places one shop here in town does, the way their rack is set up (actually a pit) they can't install long one piece tail pipes and have to weld them above the axle.
That truck could use some tweaking here and there but it's one I'd get in and just flat drive. Fly in and drive home and grin the whole way.
#16 |
Post Whore
![]() Join Date: Mar 2013
OOOOOOH Nice!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#17 |
I see the board, but what does OSB stand for?
Remember I am an Aussie. ![]()
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
#18 |
Oriented Strand Board. Kinda like plywood but no where near as good.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#19 |
#20 |
Underlayment for the flooring in your house but not what you want under the bed of your truck. Most of the time we see it as sheeting on the roofs of houses or the outside of new construction before the siding is put on. It doesn't like getting wet at all.
#21 |
Black spot on the OSB could also be from an exhaust leak, since the welds don't look all that great anyway.
#22 |
Someone likes it enough to bid $30K for it. It's a good looking truck so I'm not knocking it, but I noticed one thing that looks wrong. It looks like the bed corner doesn't fit up and creates a gap. I haven't noticed this on any of the AD builds here on the forum.
#23 | |
Derrick 1951 Chevy Pickup current project 1990 Chevy Suburban 2500 front D60 king pin and rear 14 Bolt rear with 4.88 gears |
#24 |
I recognized this right away from here
http://www.e-zchassisswaps.com/proje...php?category=2 Almost perfect...i would ditch the S10 column for somthing nicer on a truck of calibeer. |
#25 |
I've always thought (and still do) that the EZ Chassis swap kit was pretty expensive but it does solve a lot of what if's for guys with limited mechanical skills or those who can't think out things on their own.
Using their kit or not, if I was planning on doing an S-10 swap in the future I'd save every one of the under the truck photos from that Ebay add to study later. Most of the "project' photo albums on different trucks don't give you a lot to study on the hows and whys of it though.
