Old 10-05-2013, 01:28 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Torque Converter for Hot Cam and 4L60E
I am thinking about swapping my converter for a looser one to better match the rpm range of the cam. I am looking at Boss Hog and Hughes converters in the 2500 rpm range available through Summit Racing. Does anyone have experience with either of these companies?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 10-05-2013, 06:23 PM   #2
Jon01
Jon01's Avatar
Re: Torque Converter for Hot Cam and 4L60E
Boss Hogg converters are junk. I've seen mild big blocks kill them.
No experience with Hughes converters so can't comment on them.
For your combo I'd get one of Circle D's 278mm 3200 converters.
https://www.circledspecialties.com/p...converter.aspx
Reasonable price and I've seen them take a beating. One of my friends has one in his LS1 powered 78 Olds Delta 88 - h/c/i + 100 hit. It has taken way more abuse than a $400 converter should have.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 10-06-2013, 11:32 AM   #3
dkauffman05
dkauffman05's Avatar
I have the above converter and love it . It's in my 68 with crammed ls1.
dkauffman05 is offline   Reply With Quote
Old 10-06-2013, 11:58 AM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I also have a CircleD and really like it. Mines a 258mm billet single disk on a 4L85e.
gm-258mm-pro-ii-4l80e-torque-converter.aspx
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-06-2013, 05:44 PM   #5
C10_ustacould
I have been told of the circle d converters before, I think I'll give them a call and get their recommendation when I get closer to being ready to making the swap. Thanks for the input.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-14-2013, 02:23 AM   #6
Ford Assassin
Ford Assassin's Avatar
I have been running RevMax converters for the past 4 years on my personal stuff as well as customer projects. Top notch customer service, every converter is built to spec, and quick turnaround.
Currently running a 9.5" billet converter for my 4L80e.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 11-14-2013, 11:05 AM   #7
whitels1
whitels1's Avatar
I ran a Yank 2800 behind my Hot cammed 99 Camaro for 80K miles with no issues, ran a 12.7 @ 107, held up well at the track etc.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-14-2013, 01:16 PM   #8
C10_ustacould
I just installed a Circle D 2600-2800 278mm unit, installed it this past weekend. Still need to fill the trans with fluid and give it a go, but I am optimistic.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-14-2013, 01:28 PM   #9
Ford Assassin
Circle D makes good stuff. I prefer my converters alittle on the 'tight' side so they seem almost stock when driving regularly, but flash to the intended stall speed when I put the hammer down. Also, when built right, the higher dollar converters (billet, etc) don't slip as much % on the high end. This is especially important if you don't have a billet front cover and/or the converter won't lockup during WOT.
Cable
Old 11-14-2013, 03:20 PM   #10
C10_ustacould
Chris at Circle D says this one will drive like a factory unit until you stab it. I am excited to see how it performs.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-15-2013, 10:19 AM   #11
C10_ustacould
Took it for a ride this morning and I am happy so far. I will have to see the tuner to make some changes, but the converter seemed to help with the idle and pushing problems I was having. And as an added bonus it gets in the power band right away!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
