Storing my truck over winter.
No time to get my truck running this year. Here is how it sits now.
Carb off, radiator out. When I unhooked the radiator hoses the engine made a "spooky" sound like rubbing the rim of a glass of water. The engine still has antifreeze in the water jacket, I assume. I changed the oil and filter but it hasn't run since 2007. The hood is down, rags are stuffed into the water neck and carb openings, and the truck is in a dry garage. The gas tank is renewed and still out with all openings sealed. The fuel lines are all disconnected and will be replaced anyway. The battery is out. Is she OK for the winter that way? Last edited by In The Ten Ring; 10-05-2013 at 08:11 PM. |
![]() Join Date: Feb 2001
Re: Storing my truck over winter.
Sounds like you have your bases covered but I am half awake so here is a bump for you.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
When you say you assume there is antifreeze in the block, is that because when you drained the radiator it had antifreeze in it, or you just figure it has some in it?
If you are not sure, I would pour some in it just in case.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
Oh good question! The radiator was full of antifreeze when I drained and unhooked it.
If it gets below freezing in your neck of the woods you need to test the antifreeze to be sure.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Or just pull the block drains and have no worries at all.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Where is the "block drain" on a 250 I6?
If you pull the water pump (real easy) all the coolant will be out of the block. Almost all of the coolant should be out already with the lower hose removed. The water pump is at the bottom of the coolant passage anyway.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
Hmmm....
Well, with the lower hose off and water pump still on, is she OK as is for winter? I have no desire to get a new engine! |
Well how green was the antifreeze? If really green I wouldn't worry about it. You could also blow air through top outlet to push some more coolant out.
Antifreeze was basically new (maybe 50 miles on it when parked) and it was very green when I took out the radiator.
It looks like I will practically do a frame off before I get this thing running again! Things always seem to snowball for me not matter what it is I try to fix. LOL |
I may be an over-achiever in this but I have to store my truck when the army sends me overseas and when I do, I drain all the fluids out of the engine and fill the entire crankcase with ATF. I run synthetic gear oil in the transmission and rear end so I will top off the transmission and fill the read end pumpkin through the vent and I use DOT5 brake fluid because it is not corrosive. I also make sure the gas tank is full even though I drain it when I go to fire it back up. Then I use jackstands to let the suspension hang. I remove the battery if I have no electric where I store it but when I do I will hook it to a trickle and leave a couple LEDs running to ward off some of the wire corrosion. I top it off with used engine oil in a weed sprayer to hit the undercarriage with.
I put the truck back on the road by changing out the rear end oil, an oil filter and oil change to the engine, spark plug, wire cap and rotor changes and a flush to the radiator before I fill it. It's a lot of work but it's my workhorse and I've had it 17 years now and I like having the best of both worlds.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
#13 |
I think you wont have any problems if you are still worried you can also pull the rear freeze plug on driver side. I know my 250 was angled back alot so most coolant is in the rear. With coolant that new I wouldnt worry about it.
#14 |
