Best Static Drop Options
I have a 1984 Chevrolet SWB. I am looking to do a static drop. I would like to run 20" wheels. I would like to keep my drop around a 4/6 or 5/7. I was wondering what drop components will provide the best ride quality and with what components. I really like the look of a 5/7 if i can maintain a good ride quality. I would also like to know what wheel combinations i could use with this as far as backspacing and sizes. Any information you could provide and pictures would be appreciated.
Re: Best Static Drop Options
I have about a 4/6-5/7 drop on my truck. It rides really nice. I use 3" drop spindles and cut 1 coil off for the front and used a flip kit in the rear. You might have to also use drop shackles for a 7 inch drop in the rear. If you use shackles and flip kit you will probably need to do a notch on the frame but if you only do a flip kit you most likely won't need to notch the frame, depending on how much drop the flip gives you exactly.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
Diggin The SquareLife
I got 5/6 drop on mine I have 2.5" springs and spindles up front an 6" flip kit and c notch rear...if u want good ride I wouldn't cut the front springs, you can run a 20x8.5 wth 5.25" bs up front wth a 245 or 255/40/20 and rear you can run 20x10 wth 5.50" bs wth 295/40/20
Does anybody have any pics of drop with different wheel options?
I used a flip kit in the rear, 3 inch drop spindles and 1 ring cut off of the factory coil springs. The truck rides great and handles much better than before. This setup is on my 73 step side with 20x10 Dayton wire wheels all the way around.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Project Heaven in my 67!!!
Hey man, not far from you in Lorena, I havent done the drop on the 86 yet... We are getting ready to do a flip in the rear and 2.5" spindles and one coil cut up front. It should get me where I want to be as far as drop and will most likely be about where you want to be as well!
Maybe you could shoot me some pics
You can't go wrong with McGaughey's 4.5 / 6 static drop kit.
RIZ |
Frequent Flyer
My trucks is down about 6/8 with Western Chassis parts with 255/35/20s in front & 275/35/20 in rear.
I've only had 2 occasions where the front tires rubbed the inner fenders but that was on big dips in the road at highway speeds. Last edited by JWall; 10-07-2013 at 01:56 PM. |
Could you tell me the exact components you used for the 6/8 drop. I really like the look of your truck.
think im jus gona leave mine 5/7 ima run 22x10.5 rear and 22x8.5 front
sounds good i would love to see it
#13 |
im running a 6/6 drop and for some reason it looks lower than other running a 6/8 or 5/7
Jeremy '86 GMC 1500 dropped 6" in the front and 6" in the rear 2003 Land Rover Discovery Low Life |
#14 |
Mine is about a 6/7. 3 inch springs and 3 inch spindles up front with flip kit and 2 inch shackles out back. It rides pretty good. I had to take the front fenderwells out, but i never drive it in the rain so it doesn't matter. Don't know about the backspacing on the wheels since there wasn't a choice with the Boss wheels.
#15 |
Is a notch mandatory with a rear flip? With stock leafs and shackles?
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
#16 |
I just put on my c-notch on my '75 c10 today. I have 2 inch shackles and flip kit. With my bed off and the factory bump stops and bump stop brackets removed the axle came about two inches from the frame (take in mind bed is still off) then I put the bed on and axle hit the frame. So I put on a c notch kit and axle sits perfectly in middle and doesn't hit bump stops in c notch at all.
#17 |
