07-09-2003, 08:34 PM | #1 |
1969 2WD lift kit???
Hello folks,
Anyone know of an off-the-shelf lift kit available for a 1969 3/4 ton? Mine is the Camper Special which has a slightly narrower rear axle and fits 10" rims for hauling those heavy-ass old school campers. It has a front coils and a really long rear traveling arm w/ a funcky inverted rear spring holding it in place. I've checked around on-line and have not found anythign from Trailmaster, Rancho, FabTech. Also emailed tech support at Rancho and thye said 'good luck'. I can't imagine there is not a lift available for this truck. A buddy of mine does custom racing suspension and he can put something together to get 2-3 inches, btu I'm really looking for a kit that fits my application. Thanks!! |
07-10-2003, 08:34 PM | #2 |
user # 2756
The custom set up will probably be the way to go unless you install a body lift.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-11-2003, 09:40 AM | #3 |
There are parts out there like A-ams and springs but nobody has a kit. You can go BB springs on the front for a 1-2" lift if you have a SB in the truck. The rear can be done with air shocks. All in all you can get about 2 maybe 3 inches lift,
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
07-11-2003, 10:19 AM | #4 |
Since 73 - 87 front end parts swap into these trucks (with the right parts), wouldn't things like lift spindles work? As for the rear, I got no idea other than taking it to a custom shop and getting the long-arms lengthened.
Greg
No such thing as a stupid question, right? |
07-11-2003, 02:36 PM | #5 |
Rancho used to sell a kit a few years back. I used one of there's on my 3/4 ton and was able to clear 33's no problem.
07-11-2003, 04:25 PM | #6 |
Does your truck have drum or disc brakes? are the rear springs leaf or coils?
I have a 1971 chevy 3/4 ton pick up thats lifted. the front is lifted with rancho springs from a 1973-1987 3/4 - 1 ton application. (1 ton springs will do just the same) and a ball joint spacer. The rear is stock leaf springs with a add-a-leaf. It also has a 3 inch body lift and clearing 33 inch bfg mud terrains on 16.5 x 9 3/4 inch rims. I am waiting for a shop to call back and give me the go ahead to take my truck in. He is going to re-work my spindles and give me an additional 4 inches. I have called around and have no leads on any company who makes a 3/4 or 1 ton lifted spindle for the 73-87 trucks. the later spindles could be re-machined to work, but I have not heard anyone of doing this method. hope this helps |
