Old 10-05-2013, 04:55 PM   #1
gmcbigbl
gmcbigbl's Avatar
Door Window Frames or No
I'm going to replace passenger door on my 1960 Apache C-10. It has door window glass with the frame around it. Wondering if all 1960 61 62 63 doors (with just glass or glass+frame) are interchangeable. In other words will my door hardware (with glass+frame) be compatible with any door (just glass) I know window seals, vertical channel felt and weather channel will be different.
Will all doors these years accept either window? (Frame or NO Frame)
Thanks for any help.
gmcbigbl is offline   Reply With Quote
Old 10-06-2013, 11:48 AM   #2
gmcbigbl
gmcbigbl's Avatar
Re: Door Window Frames or No
Anybody have an idea???
Old 10-06-2013, 12:37 PM   #3
61K10
61K10's Avatar
pretty sure their the same, just different felts.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-07-2013, 01:55 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I read once the frameless glass was tempered and the framed windows are safety plate. Have no idea if this is true or not.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-07-2013, 09:32 AM   #5
1963c-10
1963c-10's Avatar
Marks...correct. Im my experience the metal framed glass if OEM is safety plate and non framed is tempered. You can install either in 60-63 doors. You just need the correct weather stripping kit for which style you want to install.
Door channels, division bar and window seals(fuzzies) are different
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
