10-06-2013, 12:22 AM | #1 |
Ticking Noise
Hi everyone,
Hopefully you guys can help b/c I am stumped. I am hearing a ticking noise from the driver side of the engine compartment when the engine is running. I don't know where it is coming from. I am thinking its maybe the belt or the alternator but I can't tell for certain. I thought maybe a misfire but I just changed the plugs and plug wires. I was having so many issue b/c the headers were burning the wires but I got some heat shields to solve the issue. Any Ideas? |
10-06-2013, 12:27 AM | #2 |
Re: Ticking Noise
i know on my truck the pass side furthest rear spark plug was sparking to the engine, but i changed the spark plug and it solved the other issue I was having but now I can hear a ticking through the radio. I also havent checked to see if it still is sparking, so that would be a good place to start. the best way to check this is when it is dark out look for the light of the spark, it may be hard to see if you have a street light near your house though.
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
10-06-2013, 01:56 AM | #3 |
Re: Ticking Noise
adjust the valves
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
10-06-2013, 11:01 AM | #4 |
Active Member
Re: Ticking Noise
My favorite to isolate where noises are coming from is a 2½ ft. piece of old garden hose. Put one end on the ear and the other end in various parts of the engine to isolate or at least try to determine the location.
If it's mostly when you first start it, a sticky or defective lifter could be the problem.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
10-06-2013, 11:42 AM | #5 |
Re: Ticking Noise
Exhaust leak maybe?
I'm not as good as I once was, But I'm as good once as I ever was. |
10-06-2013, 11:42 AM | #6 |
406 Powered
Re: Ticking Noise
You didnt say if you had headers or not but bad header gasket leaks can cause a ticking noise.
70 GMC 68 c10 2002 silverado 72 4x4 |
10-06-2013, 11:53 AM | #7 |
Re: Ticking Noise
headers are hard on plug wires. boots could help with that, also an exhaust leak , or lifter can give a ticking sound...the garden house or long screwdriver can help find it, I have a mechanic stethoscope that works on most noises .
10-06-2013, 11:55 AM | #8 |
Re: Ticking Noise
I do agree with the bad header gasket but my alternator is a 100 amp 1 wire conversion and is pretty noisy, I just let it do it's thing.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
10-06-2013, 12:23 PM | #9 |
Re: Ticking Noise
i'd look into the header exhaust pipe cause they r notorious for that problem
to check alt for noise take off the belt and run the engine if noise remains it is not altenator or belt if you have auto tranny check the dust shield thingy on the bottom of the tranny it is not uncommen for it to hit the flexplater teeth a sagging motor mount can cause the fan to hit the fan shroud
10-06-2013, 12:39 PM | #10 |
Re: Ticking Noise
Points and Condenser.. thinking of noise thru radio for this to make the ticking ..other than that go out at night
and run the engine in the dark and look for a wire jumping fire
When you learn a thing a day you store up smart. |
10-06-2013, 01:51 PM | #11 |
Re: Ticking Noise
I had a similar issue with ticking through the radio once and my dad showed me how to put a loose loop in the coil wire. Fixed it!
10-07-2013, 08:47 PM | #12 |
Re: Ticking Noise
Thanks Guys.
I had an exhaust leak from the header gaskets. They turned out to be a pain b/c they were stuck so I had to chip them off and clean it with a razor blade before putting the new one on. |
10-07-2013, 09:53 PM | #13 |
Re: Ticking Noise
10-10-2013, 09:58 PM | #14 |
Re: Ticking Noise
I love the sound of something fixed right!
