Old 10-06-2013, 04:14 PM   #1
mattbert56
mattbert56's Avatar
65 chevy flat bed swap. need ideas
Reaching out to anybody who might own or be doing something similar with a 60-66 Chevy, I am loosing the long box on my 65 c20 SBW to swap for an old wood flat bed, haven't been able to find nearly anything for photo reference. want to see what it might look like when its all done. any advice / pics would be much appreciated.
thanks
-matt
mattbert56 is offline   Reply With Quote
Old 10-06-2013, 04:40 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 65 chevy flat bed swap. need ideas
Old 10-06-2013, 10:00 PM   #3
Downlow2xfo
Downlow2xfo's Avatar
Here's mine before I bagged it I plan in putting the bed back on soon.
Downlow2xfo is offline   Reply With Quote
Old 10-06-2013, 10:02 PM   #4
Downlow2xfo
Sorry not swb
Old 10-07-2013, 10:15 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Here's a picture of the ol flatbed that used to be on mine. It's straight on the underneath and the guy used some rail road ties cut to 6 inch wide by 8 inch tall and the length of the frame as the supports. He cut the wood to match the bends of the frame and set the bed on and welded little foot long metal strips and it wasn't going anywere! Took me 4 hours to cut the dang thing off!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-07-2013, 12:06 PM   #6
kieth
kieth's Avatar
Flat beds were also installed by local body companies, one can use channel as the front filler from the frame to the body then have some custom made u-bolts made to tie the front down (some used wood as the filler) at the rear just add a piece of strap 1/4"- 4" x 6-8" bolt it to the frame and weld it to the body long sill. (one can weld behind the rear axle to the frame with out hurting anything) 3" or 4" channel can also be used.......
kieth is offline   Reply With Quote
Old 10-13-2013, 12:26 AM   #7
mattbert56
mattbert56's Avatar
bit of an update, truck top is painted, bed is off and the doner truck with the flat bed is in the lot. like the old wood and metal, but wondering if i should paint it gloss black, or leave it. any ideas? i'm stuck.
-matt
ps: the 1978 chevy c 20 is going up on CL soon. running 350 with 4 speed.
Old 10-13-2013, 02:28 PM   #8
DexterDog
DexterDog's Avatar
My '64 flat bed. Bed was a total loss, re used all the attaching points with new hardware and used the stock inner fenders mounted from the bottom up on the wood. Truck is lowered about 4 inches or so, if you have any questions or would like some more detailed pictures let me know. The idea for the very low deck of the wood bed is for the ease of loading bikes.
DexterDog is offline   Reply With Quote
Old 10-14-2013, 07:54 PM   #9
mattbert56
mattbert56's Avatar
pretty happy with how it turned out , it is just on long enough to weld tabs on, then its all apart for paint and new deck wood. im always open for ideas on color, someone put the thought of painting the flat bed the same color as the body. chose this green for the bottom, tops already white going to be a two tone. what do yall think?
