Old 10-06-2013, 07:35 PM   #1
comegetsome2003
comegetsome2003's Avatar
wiring harness question
I have a 82 RCSB sierra that ive owned for years.....about a year ago my 13 year old cousin hooked the jumper cables up on it backwards and melted some stuff.....haven't found anything melted but checked all fuses ect and they are good but it won't even click when you try to crank it....2 weekends ago I pulled the small block out and dropped in a 468.... i am looking for a new harness that will plug into the factory column and rewire all the electronics....i dont want the headache of tracing wires on the current harness so any recommendations on a harness to replace my factory one....thanks
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
comegetsome2003 is offline   Reply With Quote
Old 10-06-2013, 09:17 PM   #2
Greenlee
Greenlee's Avatar
Re: wiring harness question
I bet you just need to change out the fusible link up on the firewall. I would try that before entire harness. http://67-72chevytrucks.com/vboard/s...d.php?t=535553
Greenlee is offline   Reply With Quote
Old 10-06-2013, 09:19 PM   #3
comegetsome2003
thanks man ill check that out tomorrow and hope thats what it is cause i really didnt wanna rewire it lol
Old 10-06-2013, 10:15 PM   #4
comegetsome2003
so i went ahead and went out and checked it out few minutes ago......found the wire between the fusible link and the power distribution block(not sure of actual term) on the firewall burnt into.....thanks for the answer man saved me a bunch of time
