Old 10-06-2013, 10:15 PM   #1
epon
epon's Avatar
Square D Pressure Switch Model?
Think the pressure switch died allowing the system to charge to almost 300 psi before I got the battery cable pulled.
Here's the current switch, Square D 9013 FHG 12 :
Do I need the 9013FHG-12J52M1 running 95-125 psi? I would like the one with the lever to turn it off and noticed theres also an option for a pressure relief, are those beneficial for a dual via air setup? The current one doesnt have that as far as I can tell.
Could I spray contact cleaner or tap somewhere to encourage this one to work a bit more?
TIA
epon is offline   Reply With Quote
Old 10-07-2013, 06:38 PM   #2
epon
epon's Avatar
Re: Square D Pressure Switch Model?
Got a better pic and looks like it's fried:
I could swear the current switch was turning off the compressor at ~200 lbs in the tank and if thats the case, from reading this tech sheet, the correct part would be a FHG42 turing on at 100 psi and off at 200 psi. I'm guessing internal means female thread like mine in the pic. Also still wondering if I should get the pressure relief and on/off lever options.
Current system has 4 x 2600 bags via 3/8" line and controlled with switch activated solenoids.
Old 10-08-2013, 12:34 PM   #3
epon
epon's Avatar
Going to give a 9013FHG42J59M1 a shot. Fixed differential at 135 - 175 for $32. The adjustable version from 145-175 was $125.
For reference the input to the switch pictured above is called 1/4" NPSF Internal.
Old 10-08-2013, 06:29 PM   #4
epon
epon's Avatar
Smart kid on the internet also suggested I wire in a 50a relay to prevent this from happening. I'll update here when that gets done in case the documentation is helpful for others.
Old 10-10-2013, 10:19 PM   #5
epon
epon's Avatar
Installed today with a tee for an overpressure release valve. Works great and the off/auto lever on the pressure switch is super handy.
I also misunderstood the way this switch is rated. It's an adjustable range with a fixed differential of 40 psi. Tightening the nut on the shaft results in higher cutoff pressures. With the nut almost all the way down I saw 270 psi on my gauge before I backed the nut off enough to turn it off around 240.
I see test pressures of 400 psi for the bags and working pressure numbers of 150 for durability. Should I be lowering that 240 number? I already go up on the front a tad slow for liking at the end of the lift.
:thumbsup:
Old 10-11-2013, 03:46 PM   #6
king-918
king-918's Avatar
I would not use these again. Mine almost set my truck on fire
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 10-11-2013, 07:15 PM   #7
67c10rustbuket
67c10rustbuket's Avatar
Are you using this on your truck? 12V?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-11-2013, 07:31 PM   #8
epon
epon's Avatar
yikes king-918, was that because it wasnt on a relay?
Yes 67c10rustbuket, this is on my 12v 82 C10.
Old 10-11-2013, 07:59 PM   #9
king-918
king-918's Avatar
No relay If I recall, I also didn't install it. It came with the truck. I have since rewired the truck With ebay pressure switch and relay
<----Christopher
Oklahoma
