Old 10-07-2013, 01:03 AM   #1
PAWS 72
PAWS 72's Avatar
Rear Brake Hose
Thought I would post here, But
How are you guys getting to the fitting at the hose and metal line broke loose. It is so tight spaced I dont see no way of getting it loose other than cutting the metal hose and piecing it back together.
Any help is appriecated.
PAWS 72 is offline   Reply With Quote
Old 10-07-2013, 01:44 AM   #2
marvgarr68
marvgarr68's Avatar
Re: Rear Brake Hose
I am trying to follow you now are you talking about the metal line on the frame rail? If so just use a 7/16 flare wrench on the line and a 5/8 flare wrench on the hose. If your talking about the tee fitting on the rear axle then take both metal lines off the tee with a wrench 3/8 flare if I remember right. Now take a 9/16 open end wrench and turn the tee off the line then take the keeper off the end and the hose comes out. The bracket for the hose holds the hose from turning but its a good idea to put a wrench on the hose anyway.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 10-07-2013, 08:24 AM   #3
PAWS 72
PAWS 72's Avatar
Re: Rear Brake Hose
It's the hose end that connects to the line at the frame.Not the tee end. I can handle it.
The end at the frame will be a bogger.
Old 10-07-2013, 08:55 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Rear Brake Hose
I agree and haven't took the time to swap the S/S line I bought for it last winter. I have been putting it off for this very reason.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-08-2013, 02:00 AM   #5
swamp rat
swamp rat's Avatar
Re: Rear Brake Hose
I also had a time dealing with mine, I have a flair nut wrench but there was times when you needed a second one with the flair clocked a little differently to deal with the tight space. keep at it..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-08-2013, 08:35 AM   #6
PAWS 72
PAWS 72's Avatar
Re: Rear Brake Hose
Havent started it yet. Just wondering if you take the bed off if it would be easier to deal with. The bed needs to come off anyway but wasnt wanting to right now but if it would help I'd go and pull it.Just a thought.
Old 10-08-2013, 08:33 PM   #7
bollybib
bollybib's Avatar
Re: Rear Brake Hose
I did mine with the bed off (along with a bunch of other stuff) and it was still a little awkward to do as I recall.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-08-2013, 08:46 PM   #8
PAWS 72
PAWS 72's Avatar
Re: Rear Brake Hose
I still cant decide if I want to do it or get a friend of my son's to. He is always wanting to come help me do a few things some times. He works on his stuff all the time.
Save me a few head aches.I think.
Old 10-09-2013, 03:42 AM   #9
68 TT
Still plays with trucks
68 TT's Avatar
Re: Rear Brake Hose
It is tucked inside the frame rail so nicely that it isn't any easier bed on or off so not really worth the time to pull the bed.
3/4 of the ones at that spot I have pulled apart were rusted to a point the nut was completely seized to the hard line and twisted the line in half trying to get them out. No amount of WD40 pre-soak helped. Hope you don't run into this.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
