Old 10-07-2013, 01:44 AM   #1
piratedog
Cool 70 gmc drum to disc
(70 gmc) hey everyone, only my 4th time posting for info, i scanned the posts for a while but was unable to see a clear answer for a swap i want to do.i want to swap my manual drum front brakes to manual disc( i like the feel of a manual brake) i have a complete front end for a 71 with disc including crossmember and rear axles, can i bolt this crossmember right in to my truck complete using my dual reservoir master and proportioning valve (if im keeping manual brakes) and will the axles swap right in ????
thanks in advance!!!!
piratedog is offline   Reply With Quote
Old 10-07-2013, 02:14 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 70 gmc drum to disc
I would use the master and prop valve off the manual disk set up. Everything else should bolt right up.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 10-07-2013, 06:58 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
disc and drum use different master cylinders. The master cylinder from a boosted truck will bolt right up to your firewall
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-07-2013, 08:45 AM   #4
CC69Rat
CC69Rat's Avatar
For the rear axles, If you want to shoot me a PM, I'll help you measure and I can tell you for sure without having to take yours apart.
CC69Rat is offline   Reply With Quote
