Best suspension upgrade?
Ok boys! What is the best suspension upgrade for our trucks?
Its a Truck Thing......
Re: Best suspension upgrade?
Whats the budget?
Adding a front sway bar makes a huge difference. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
Trying to set my budget. Looking for input.
What year? Sway bar, disk brakes, new panhard bar/ trailing arm bushingss, the list could go on and on. Is your front end rebuilt? Ball joints, tie rods, a arms all nice and tight?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
The oddest Todd around
Sway bar.
Also, use the ECE drop mounts when putting it in. That way you won't hit curbs with it when parking. Keep in mind that if there are any problems with your front end, a sway bar will find them quick. I put a 1 ton sway bar in my truck, and a week later I was finding out that my ball joints and upper/lower control arm shafts were all shot... All Moog now.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
Old member
1st= Disc brakes, if u don't have them.
2nd= front sway bar 3rd= rear shock locator behind the trailing arms 'no limits' is the one I have. 4th= rear sway bar 5th= rear disc brakes Just my opinion. New bushings is a regular maintance issue and no upgrades to me as with a lowered are full height sitting truck. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Totally agree with Andy on daily driver, every day street machine. (most practical)
If you're going More Serious, ignoring budget, full frame, chrome moly tubular upper and lower control arms, ground control coil overs, Eibach springs, KYB-AGXs, rack & pinion, 13" discs (front) 9 inch Ford rear with discs. new rear leaf spring packages, urethane bushings throughout, big sway bars front and rear, adjustable heim links. You did say "Best" didn't you?
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" Last edited by Lees68GMC; 10-07-2013 at 09:41 AM. |
Thanks guys! Been having issues logging in the past few days. My truck has front discs. I am getting ready to do new bushings, ball joints, and such. Trying to decide ride hight ie to lower or not to lower. I appreciate the guidance.
What is the benefit to the rear shock relocating? I thought it came in to play only when lowering? Last edited by mike88a; 10-09-2013 at 12:42 AM. |
![]() Join Date: May 2013
quality front and rear sway bars , and quality bushing for the same , the stock front is not bad but if your bushing are gone its useless , add a rear and get good bushings
#10 | |
Old member
![]() Quote:
![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=477839
Lowering your truck will improve handling also ' if you go with the cpp kit ask about their shocks , mine are a few months old and leak , i would not purchace them again , they leak bad
Just opinion from another Old Fart. I'm 6'-2" 275 Lbs.
With my 68 GMC SWB at stock ride height, I always had to pull myself up, using the steering wheel, onto the bench seat. Working under-hood I had to use a step stool and still could barely reach the carb on my V8, while laying over the radiator support, being stabbed in the belly by the hood latch. NOW after a 2-1/2" front drop and 2 inch rear drop, working under hood is NICE, like working on a Chevelle, standing on the ground I can reach anything under-hood including the firewall. It's also really nice to simply open the door now and slide in, more like a full size car too.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
#13 |
Interesting!
#14 |
I think the three biggest things that made the best improvement in my trucks ride were the shocks, front sway bar and alignment. I'm not sure if you can find a shop that has the ability but heres a thread I posted on the best way to get the best alignment. Even if their machine doesn't have this function its still the best and only way to do it as far as I'm concerned.
http://67-72chevytrucks.com/vboard/s...d.php?t=582187
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
