Old 10-07-2013, 08:45 AM   #1
72MARIO
72MARIO's Avatar
speedometer works only in 4wd 1990 Burbn?
Works to 90km about 55mph in 2wd If I get it faster and snap out of the throttle it will jump to speed. As soon as I put it in 4wd it works perfectly....any ideas ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-07-2014, 10:37 AM   #2
72MARIO
72MARIO's Avatar
Re: speedometer works only in 4wd 1990 Burbn?
anyone ?
2005 TAHOE DD
Old 01-07-2014, 12:53 PM   #3
Ski-me
Ski-me's Avatar
Check your speed sensor pickup on the T-case. I've seen a few posts on this type of issue lately. Also, check the twisted wire coming from the t-case to your DRAC module. Be sure there aren't any frayed wires. I'd probably try replacing the t-case sensor just for the heck of it. You might just find another one at the junkyard or a new one.....
http://www.autozone.com/autozone/par...2_20285_147510
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 01-08-2014, 09:10 PM   #4
72MARIO
72MARIO's Avatar
That sounds like what I was thinking the abs light came on. I just tossed the abs computer I didn't care for the way it operated. If the speed sensor went bad that would make the abs computer throw the light on. Going to try and find a new one in the morning..
Thanks !
2005 TAHOE DD
Old 01-08-2014, 09:12 PM   #5
72MARIO
72MARIO's Avatar
I should add that the speedo stopped working correctly in 4wd this week
2005 TAHOE DD
