Saginaw 4-speed transmission/additional driveline parts
Saginaw 4-speed transmission for sale. Believed to be from an early 70's Firebird. Has the 3.50 first gear. 10 spline input shaft. Just installed a new input shaft bearing (old one had a slight rumble) and replaced all gaskets and seals. Shifts smooth and works well. Will fit in place of Saginaw 3-speed. Nose piece is the larger version for the later bellhousings. Speedo gear is for 3.73's. Includes a Hurst reverse light switch.
Also available: Hurst shifter custom modified to fit with bench seat. Trans and shifter were used for approximately 1200 miles. Both work very well. Also have an 11" RAM clutch kit for small block Chevy. Like new, used for about 1200 miles. 10 spline input shaft. Also have a competition grade flywheel for internally balanced, 2 piece rear main seal. Drilled for 10.5" and 11" clutch. 168 tooth. Used for about 1200 miles. 1-Piece driveshaft. Originally for short bed truck with 6-cylinder. Input fits Saginaw 3 or 4 speed. New Moog u-joints installed 1200 miles ago. Pick up only, this stuff is way to heavy to ship. I'm located in Southern NJ close to Philadelphia. Trans: $400 Shifter $125 Clutch: $80 Flywheel: $125 Driveshaft: $75 If you want multiple items price can be negotiated. I'm open to offers as well. I pulled all of these parts out to install a new Tremec TKO.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 Last edited by Lattimer; 10-07-2013 at 10:19 PM. |
Re: Saginaw 4-speed transmission/additional driveline parts
bump
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Bump.
Make an offer if you need any of this stuff. The prices are best guesses based on what I paid.
ttt
![]() Join Date: May 2008
Do you by chance still have any of these items for sale?
All I have left is the driveshaft. Everything else sold on craigslist.
![]() Join Date: Sep 2002
Might be interested in the drive shaft, can u tell me how long measures?
Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
I'll pull it out and measure it. It fit a short bed L-6 with the 3 OTT.
![]() Join Date: Apr 2013
Do you still have this stuff? Please call me at 609.698.7714. I'm interested in everything.
Only thing left is the driveshaft.
Tags |
iece driveshaft |
