new to board have some questions
hey just picked up a 69 c10 stepside, runs and drives just like everything its a project. my first biggest thing is under dash the wiring looks like crap and i think its time to replace it. under the hood its been replaced already. Anyone know where i can find that? anyway my biggest problem i want to figure out is why the headlights dont work but all the markers do. i replaced dimmer switch still nothing. i dont even get power to headlight plugs. thats one of my main concerns at the moment. plans for the truck is to restore it, make it a someone daily driver. ill have alot of questions as i go through the truck as its my first c10 that i will restore. ive restored a 1970 mustang that i did a few years back.
Re: new to board have some questions
Welcome to you from eastern parts of Arkansas. I know you will find a wealth of help on this site , I hang here and the paint and body as I have a body shop and help a few people out over there from time to time. American autowire is the place I would look to for a factory type replacement wiring harness. I have used them in the past and they are top notch. There are several board members here that are venders for them and all are pretty good, Southern Kentucky classics come to mind real quick I have used them before excellent service, as well with LMC they have every thing. Just look in the vendors section for a few ads then find the one that feels right for you. Jim
![]() Join Date: Jul 2013
Welcome to the board! '69-'70's are near and dear to my heart.
American auto wire is a good choice. Check for a blown fuse on those lights. Lots of information here and great people. Look forward to some pictures... Remember it didn't happen if there are no pictures
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
Oh it happened all right drove 4 hours through the Catskills to go pick this one up. I tested That the lights actually work and they do just nothing from the switch. What activates power from the switch which wire? I wanna try wanna try and get things to work so I can restore/ drive the snot out of it
I'm not a wiring expert, but I believe the power to the headlights goes thru the headlight switch, which apparently causes a lot of load on the switch. There is a member on here that sells a kit to have the primary power for the lights run through a relay, and then just be switched by the headlights. Apparently it takes the load off the switch and makes the lights brighter too. I plan to do this to my truck when I get close to putting it back together. Here is a link to their sale thread.
http://67-72chevytrucks.com/vboard/s...ight=headlight Looks like a nice truck, have fun with it.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
How does that connect to the dimmer switch? Curious bc that's all I may need to get them going again
If your wiring is really hacked up, it may be time to replace it. Me personally I would pony up for a factory harness from 'Lectric Limited or M&H, or possibly a really nice used one if you can find one. You can buy the do-it-yourself style from Painless and others, but if you do not take the time to chase down factory connections and solder and shrink wrap and route then you are wasting your time IMHO. You may save on the front end, but if your time is worth anything, it will cost more in the long run. The only time I would consider doing those is on a heavily modified truck with lots of add-ons that need wiring. Just buy a factory correct harness and replace it and be done. My .02
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Someone replaced from voltage regulator to firewall plug with a m and h factory replacement I'm gonna have to give them a call and see what it costs.
Sorry.. I know nothing about wiring, and very little else. Just wanted to welcome you to the site.
That is one nice looking truck you got there. Lots of great helpful people here that Im sure can help you with any issue you may find
71 swb 350/4sp manual 5/7 static drop |
#11 | |
#12 | |
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
#13 |
Welcome to the Forum
#14 | |
Faxon Auto Library on CD Rom 30.00 http://www.faxonautoliterature.com/C...FY97QgodsmQARA Amazon ---Hardcopy $40.95 ![]() Ecklers Trucks--Hardcopy $41.99 http://www.ecklerstrucks.com/1967-72...ly-manual.html Tuckers truck parts---hardcopy $33.99 http://www.tuckersparts.com/Factory-...l-L-6772F.html |
#15 | |
#16 |
The only thing with that shop manual is the pictures are so dark it's hard to see anything. I guess the copier was set to "dark" and that's the result for the reprint.
#17 | |
#18 | |
RAT1968 '68 Cab/'71 Parts
Youey, I'm not big on *advice*...But in this case, I have to chime in on what *I* did that worked for me. First, Fitz is more than correct. Get a book...Get THAT book. I only have the other two basic books for back-up of diagrams, etc.. I also got a year-specific electrical diagram pamphlet from Early Classic Enterprises. Next, it's coming in to winter. So, I strongly suggest that you download the full color wiring diagram, an offering from a gracious Forum Member. Print it out. In color. Paste it together in the best way you can. I laminated the 8.5 x 11 sheets and cut and pasted them together with clear packing tape. Now, you have something to do on those cool/cold winter nights in front of the fire. Instead of TV, you and your favorite beverage (mine's coffee...just 'cause I...Well, never mind...). Now, play school. There are no stupid questions. Rest assured, I'm the most appropriate person to "say" that. On a related note, I've wired two trucks from front to back with M & H harnesses. I wouldn't use anything else. They are easy plug and play. And even much, much easier if you know what you are hooking up when you make the connections. My $.02 Welcome to the best place in the world of 67-72's And, oh, Here's your truck turned right-side up.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#19 |
I bought my BIG BOOK from amazon. Got it used for about half price.
The light switch has a #10 red supplying power to it. Nice truck I love fat bottomed girls!
#20 |
Thanks for all the advice and yes it's a stepside. After screwing with it for about half hour today found that the switch for the high beams is bad causing no headlights. Easy enough
Replace it and it should be good. Cleaned up motor today dropped some new plugs in it, ran some mystery oil down the carb runs a lot better now going to change cap and rotor also just for fun and maybe wires. Won't be long I'll be doing the body work nice to work on that type of stuff in the fall. Summer sucks to do body work too hot. But anyway there's always light at the end of the tunnel!! |
#21 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#22 |
This link will help you too, download the manuals you need to your computer.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016 Also, for years i have had a Chilton repair manual and hated the piss pore mechanical drawings so i recently got a Haynes manual, it had much better photo's and i like it better, but i have found discrepancy's between then in areas like torque spec's. The download is factory and i trust it more, but there are times i don't wanna drag my dirty self inside the house and sit in my good chair and research stuff with my dirty hands so i like having the other manuals.
#23 | |
![]() Join Date: Mar 2012
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
