rear leaf spring bush removal
Hi
How is the best way to remove the front bush on the rear leaf spring mount on the 57 truck? I have removed the locating pin, but unsure the best way to remove the bush, so I can remove the leaf spring. There must be a trick to this? Which side should it the bush come out? (inside or outside?) Do I need to remove any parts (running boards?), as there is no room to get a hammer in there, so I guest I need some sort of compression tool? Gary
1969 Mercury Cyclone, 390GT, 4 speed, 23000 miles 1970 Plymouth Superbird, 6PK, 4 speed 1970 Ford Mustang 428 Cobra Jet, 4 speed 1970 Ford Mustang Boss 429, concours (just sold) 2010 Husqvarna TC450 MX bike (it hurts me, everytime) Last edited by superbirdkiwi; 10-07-2013 at 06:29 PM. |
Re: rear leaf spring bush removal
It might be easier to remove the spring and use a hydraulic press to remove it. That is how I have changed them. Good luck.
#3 | |
thanks Gary
1969 Mercury Cyclone, 390GT, 4 speed, 23000 miles 1970 Plymouth Superbird, 6PK, 4 speed 1970 Ford Mustang 428 Cobra Jet, 4 speed 1970 Ford Mustang Boss 429, concours (just sold) 2010 Husqvarna TC450 MX bike (it hurts me, everytime) |
![]() Join Date: Jul 2012
Are you talking about the main pin? Both of mine came out pretty easy once the retaining pin was removed. Did you try giving it a sharp rap with a BFH?
#5 | |
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
#6 | |
Cheers
