POWERTRAX lockers
Does anyone know anything about these things? Are they easy to install and are they good for street race ??? Does anybody run these in there trucks/any problems. I might be buying on shortly and bassicly want to know the in's and out's of them...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Don't do it. They are just OK for low power applications, but if you put any real grunt to it they tend to unlock. All of the guys I know who had them, sold them, then bought a true limited slip.
Just suck it up and get an Eaton posi from Tom's Differentials ($280) and pay the installation or learn to do it yourself.
MPG...hmm..more like GPM
![]() The one thing that made me stray away from posi's was the fact that they wear out(eventually) and they still don't deliver 100% of the power to the wheels. They all have a certain amount of slip built in. The only thing i can think of that would make the lockers unlock suddenly is if your diff. housing is worn or the thrust washers you use aren't thick enough.(the manual specifies the clearance between the two halves should be between .045 and .070, anything over .070 and they say you should replace the case or get thicker thrust washers if thats the problem) They are simple to put in, they say you can reuse your pinion shaft and thrust washers but i would recommend replacing them anyway(they're 30 some years old ![]() The only reason you wouldn't want one is if you are wanting something that is unnoticeable because these aren't. You hear it ratchet when you go around corners and you can feel it when it locks up. It will whip the rearend right around if you goose the throttle going around a corner. but i think its advantages far outweigh the few disadvantages it has and it is great when you stomp the pedal and lay 2 tire tracks ![]()
(Looking for 67-72 shortwide or shortstep bed) 71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires ![]() 85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one. Last edited by 71MoneyPit; 07-10-2003 at 02:24 AM. |
Just wait awhile, you will have nothing but problems with it. I thought the world of mine until it started to unlock on me and send me across two lanes of traffic. I can't believe they still sell this unsafe crap. Save your money and buy something like Mike C said.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
It followed me home?
anyone else? I was also looking at powetrax
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I am also one that hasn't had any problems. Mine has been in for about two years and works as good now as it did when first installed. One of the things I did was take my time on the shims to make it tight with minimal slop. I use my truck to push sprint cars and it hasn't failed yet.
Well the score is two for two so I need more imput. I dont have a high horse motor maybee 300-350 hp but I run 15x10 with 295-50-15 and I just want something less harsh than a minispool but can still put what little power I have to the pavement.
I'm running the Eaton behind a pretty stout 427. Installation was easy and I haven't had any problems with it at all. Don't know much about Powertrax lockers, but the gearheads I know all recommended the Eaton and some of them are puttin out some serious H.P. Very satisfied with the Eaton.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi. |
14.1 @ 96MPH
I've heard too many bad reviews and not enough good ones for me to even consider one. Whenever I get the money and the time, I'll go with an Eaton, or maybe an Auburn...
Project1970 - LS1 Swap Complete! ![]() |
#10 | |
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
Fabricate till you "puke"
I was advised by a local driveline shop NOT to use the Powertrax on a high HP application. they should be fine on closer to stock power levels, & normal driving usage from what I understand. I have thought about using 1 in my 78 K 20( 270hp sb, & not used too hard). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thanks for the replys and I think I'll stick with the open rear until I can afford another unit. Can ya'll shot me some prices on posi units and set up cost in your area?
#13 |
![]() Join Date: Feb 2001
I've got Eaton's on my 402BB 400 THD w/o any problems so far.
