10-07-2013, 08:10 PM | #1 |
Pitman arm from centerlink
How do I remove my center link from the pitman arm when there is only a nut on one side? The nut spins, but the whole stud does. I don't know how to hold the one side from spinning, any suggestions?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
10-07-2013, 08:12 PM | #2 |
Re: Pitman arm from centerlink
Here is the other side
10-07-2013, 09:00 PM | #3 | |
I have a pneumatic die grinder with a cutoff wheel for that kind of work but use what you have.
Gale Gorman '54 3100 '67 C20 stepside |
10-07-2013, 09:08 PM | #4 | |
10-07-2013, 09:14 PM | #5 |
You can also use a pickle fork to tighten up the slack enough to turn the nut off.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-07-2013, 09:26 PM | #6 |
I'll try the pickle fork first then get the grinder out as a second option. Thanks.
