Old 10-07-2013, 11:32 PM   #1
DennisP
DennisP's Avatar
Disc conversion on C20
Hi all, I got a couple questions. I'm going to do a front drum to disc conversion and add power brakes to my 68 C20. I see available dropped spindles for the front. Would this be what I need ? I would like it to be 2.5" or 3" drop. Would I also need shorter springs? I guess I'm confused wether I need just dropped spindles with stock springs or do I use shorter springs AND dropped spindles, or just shorter springs?
Also in regards to the rear, Is 4" about the max I can lower without notching the frame? Im pretty sure I read here some ware that that is about max.
Thank you all for any help, I'm ready to make the purchase and want to make sure I don't buy a bunch of stuff I don't need.
DennisP is offline   Reply With Quote
Old 10-07-2013, 11:44 PM   #2
DennisP
DennisP's Avatar
Re: Disc conversion on C20
The company I was looking at to purchase my parts from is POL performance online. They are really the only ones I could find that carry C20 lowering stuff.
Has anyone had any dealings good or bad with them?
Old 10-08-2013, 12:13 AM   #3
chevyblazer
chevyblazer's Avatar
mine is lower like 3''
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 10-08-2013, 12:27 AM   #4
Vova
Early classics makes the c20 drop spindles.
I'm selling a brand new pair. The ones I have I thought were for a 71-72 but you can ask them if they would work on your rig.
http://67-72chevytrucks.com/vboard/s...d.php?t=599212
Vova is offline   Reply With Quote
Old 10-08-2013, 12:42 AM   #5
DennisP
DennisP's Avatar
Thanks guys. I am looking at a complete kit, rotors,spindles, power brake booster and master cylinder, ball joints, tie rod ends, the whole nine yards.
Question is. Do I order stock height and use shorter springs? Or do I need both dropped spindles and shorter springs?
Old 10-08-2013, 12:58 AM   #6
frank69
you might need to do a combination to get more than 2in unless you can get more than a 2in drop spindle then you run into the problem of wheel hitting lower a frame
frank69 is offline   Reply With Quote
Old 10-25-2013, 01:59 PM   #7
TOPTRUK
Vova,
Do you still have your spindles available?
TOPTRUK is offline   Reply With Quote
Old 10-25-2013, 02:18 PM   #8
Vova
Originally Posted by TOPTRUK View Post
Vova,
Sorry they are sold.
Old 10-28-2013, 02:15 PM   #9
TOPTRUK
Did you ever get confirmation whether they would fit a 69? Just curious. Thanks!
Old 10-28-2013, 03:21 PM   #10
Longhorn 70
Longhorn 70's Avatar
I got the complete kit from POL. It works great BUT I did have problems. I received the kit in reasonable time. There were some parts that weren't right. I started the install, had one side torn down and found that the upper ball joints and outer tie rod ends included in the kit were incorrect. As I live in an area with HOA, I had to put it back together so I didn't get in trouble with them. As it was on a Saturday afternoon and they were closed I had to buy the ball joints at AutoZone. Though they gave me credit for the ball joints when I sent the wrong ones back, it didn't cover the cost for me plus I had to pay shipping.
The tie rod ends, were replaced with no charge.
On the PLUS side, their customer service is great!. When I called and spoke to someone about an issue, that person gave me their attention, time and when done their extension if I needed to call back.
I would do business with them again.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 10-28-2013, 04:58 PM   #11
Scott>72-GMC
Scott>72-GMC's Avatar
So glad I don't have hoa
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 10-28-2013, 06:27 PM   #12
MSHax
MSHax's Avatar
That's great to know, there are too many issues with the alternative company for this kit.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
MSHax is offline   Reply With Quote
Old 10-28-2013, 08:22 PM   #13
Longhorn 70
As a note I talked to the guys at BlackBird Custom Trucks and they told me if I couldn't find a stock height kit they may be able to put one together for me
Old 10-28-2013, 09:03 PM   #14
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I used POL for my complete C20 front disc conversion on my '69. I wanted to keep the 8-lug set up and glad I did. The only problem I had was slightly leaking master cylinder, which they promptly replaced. I did a stock height conversion so can't offer any insight on the drop kit. I was very pleased with their customer service.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 10-29-2013, 02:39 PM   #15
DennisP
DennisP's Avatar
Thank you for the input guy's! The reason I wanted to go with POL is they are only about 3 miles from my home. I purchased the 2.5" drop spindles and dics power brake conversion kit as well as 1" front and 4" rear shorter springs, shocks, and track bar. Only problem I had was the track bar was too short. Took it back and got the correct one. Everything went together well.
I also added new rear drums, brakes,wheel cylinders, and brake spring kits.
I will post before and after pics when I can get out there with my camera.
Old 10-29-2013, 02:49 PM   #16
DennisP
DennisP's Avatar
Longhorn 70, What's HOA?
Old 10-29-2013, 03:28 PM   #17
Longhorn 70
Home Owner's Association. Pfffft these guys don't want my truck on blocks in the yard.
Old 10-29-2013, 04:42 PM   #18
Scott>72-GMC
They would hate me lol. I have a shop but love working in the drive
Old 10-29-2013, 05:53 PM   #19
DennisP
DennisP's Avatar
Here are a couple before & after pics of the lowering proj.
Old 10-29-2013, 10:11 PM   #20
Longhorn 70
Nice new stance!
