Old 10-08-2013, 08:54 AM   #1
bundy
4L80e in a square
Ok im sure someone has already done this and i am hoping for some help. I am building a CCSB and have a oppturnity to pick up a 4L80e for a good price. I am using a sb 406 and wondering will the 4L80 bolt up? what transfer case will i need? and how do you defeat the "e" part of the tranny. i belive compushiift used to make a controller but i cant find that product anymore. thanks again!
bundy is offline   Reply With Quote
Old 10-08-2013, 08:02 PM   #2
clinebarger
Re: 4L80e in a square
http://www.hgmelectronics.com/produc...s/compushiftii
If you want to manual shift without the controller...http://www.transgo.com/products.php?...dcountview=Yes
A 4L80E will bolt to your 400sbc, 4wd stuff isn't my gig...
clinebarger is offline   Reply With Quote
Old 10-08-2013, 08:11 PM   #3
MalibuSSwagon
4L80E/NP205 swap
MalibuSSwagon is offline   Reply With Quote
Old 10-09-2013, 12:21 AM   #4
bilfman
bilfman's Avatar
I did the swap TCI has a controller that is easy and awesome. The 4l80e/np205 link is my build. All in all was a pretty standard swap
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 10-09-2013, 07:01 PM   #5
nekkidhillbilly
it was in 91 squares fyi
nekkidhillbilly is offline   Reply With Quote
Old 10-10-2013, 02:55 AM   #6
andrewmp6
Yeah 91 crew cab square body used the 4l80 np205.The newer trucks used a few different t case but i think they are the wrong side drop.They do make adapter kits for this but i think you need a 2wd trans to use it.
andrewmp6 is offline   Reply With Quote
Old 10-10-2013, 09:08 AM   #7
bundy
the TCI looks like its the easiest and the priice is less than the others. what transfercase can or should i use? my other square has a nv3500 with a 208, what is the spline output of the 4l80e. did you have to add the TCI TPS ??
Old 10-10-2013, 06:17 PM   #8
clinebarger
what is the spline output of the 4l80e?
32 spline, Same as TH400.
Old 10-11-2013, 01:03 AM   #9
bilfman
bilfman's Avatar
You have to have a tps for the TCI unit. You can make a junkyard one or order a pre made kit.
