Old 07-10-2003, 12:21 AM   #1
Merl4
Rear end swap
I'm removing the 6 lug stock rear end from my 1968 StepSide. I'm open for suggestions as to what make or model or rear that will fit and give a comfortable gear ratio.
Thank You.
Merl4 is offline   Reply With Quote
Old 07-11-2003, 08:45 AM   #2
crazy longhorn
Fabricate till you "puke"
71-72 will get you into a 5 lug axle in the 1/2 ton trucks. the rear diff is aprox 1 1/2" wider overall, but shouldnt be a problem. (bolt in). as far as ratio, for a 3.73 look at the I 6 stick trucks for a donor......V8 auto equipped trucks should have a 3.07 gear. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-11-2003, 05:15 PM   #3
krue
Designated A-hole!
krue's Avatar
What he said....and welcome to the board!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
