I6 to SB clutch linkage
I replaced my 250 with a 350 GM crate. Moved the mounts to the small block location. I have Hedman Headers that are specific for a manual transmission. What do I need, or to fabricate to get my linkage to work.
Re: I6 to SB clutch linkage
IIRC you need to cut about 1/2 inch off the end of the zbar tube and use a bracket like in this link.
http://www.bigdoggarage.com/Clutch.html |
Still plays with trucks
I used a piece of 1/8" steel flat bar bolted between the two mount bosses on the block and drilled & tapped it for the pivot ball where it lined up with the frame mount bracket.
Welded another layer of 1/8" flat bar on the back side between the bosses and used a thin nylock on the back side of the ball stud to lock it in place.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
I don't think my ball stud is threaded. I can spin it, but it won't turn out. Looks like it was pressed in and peened on the back to keep it in place.
What I really want to do is switch to hydraulic, but it looks expensive. Has anyone done this? |
Mine was done by the PO when he put a SB in it. (not hydraulic, Im talking about your original post). And I guarantee he did it as cheap as possible. Ill take pictures when I get home. Maybe that will help at least get you going until you get something better.
71 swb 350/4sp manual 5/7 static drop |
I had found a threaded clutch pivot ball off summit and used it on my swap. I seem to remember hearing that some blocks had the threaded hole to accept it, some didn't. Mine did. Threaded ball in to block and everything worked without any modifications.
Note that my 350 is in the rearward 6cyl position and I have ramhorn manifolds.
1967 C10 Stepside - "Minty" 1972 GMC 3500 - "Rojo Grande" |
I just removed my complete manual linkage setup when I went to auto. PM me if interested.
