Old 10-10-2013, 01:29 AM   #1
Iron Hauler
Iron Hauler's Avatar
C30 motor removale
I have a 72 c30 that I want to remove the motor and front suspension in, I have the truck on a lift and wondered if its possible to drop the motor and cradle together as a unit out the bottom? Can you reach all the cradle bolts with the motor in the truck? I was thinking unbolt it while its on the ground and then just lift the truck up leaving moor and suspension on the ground.
Iron Hauler is offline   Reply With Quote
Old 10-10-2013, 09:56 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: C30 motor removale
I doubt it will work that way.The engine towers lay on top of the frame rails and would hang up.I think you'll be miles ahead to pull the engine and the crossmember separately.You'll want to separate them to regasket and clean/paint them anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-10-2013, 11:28 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
That could never work unless you torched the frame off.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-10-2013, 11:39 AM   #4
kwmech
I've done that before when I had access to a huge forklift and was younger and more stupid.. Tell you what, it was a huge pain in the a... with everything that hooks to the engine form the top. Way easier to pull the engine first
