Old 10-11-2013, 12:43 PM   #1
Shortie
Junior Member
Shortie's Avatar
Front crossmember swap question using c20?
Getting conflicting answers using search so I'll just ask
I have a 69 c10 with stock crossmember and 80s heavy half suspension
I want to build a raised front crossmember, and am wondering if a 73-87 c20 crossmember is usable.
Some people saying width is deferent or that lower arms mount differently where others say just some holes
Wanting to use only the crossmember and my current arms
Shortie is offline   Reply With Quote
Old 10-11-2013, 02:21 PM   #2
jimmydean
jimmydean's Avatar
Re: Front crossmember swap question using c20?
The C20 crossmember on my '66 is different than the way the lower arms attach on my '75 C10 crossmember. The 3/4 ton uses a different mount than the 1/2 ton on the lower arms. It's my understanding the upper arms are the same.
Someone smarter than me might have more info.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-11-2013, 06:32 PM   #3
SCOTI
SCOTI's Avatar
I notched a 73-80 1/2 ton x-member & installed it into my 68 1/2 ton. I then removed the notched x-member from the 68 & upgraded to a Dropmember. I took that same 1/2 ton notched x-member, dusted it off & it's now sitting under my 89 C30 CC dually. I'm using C30 lower arms & pre 73 C10 uppers w/a C30 BJ.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-12-2013, 01:26 PM   #4
Shortie
Junior Member
Shortie's Avatar
Ok, and the arm mounting points were the same? I Just don't wanna mess around pulling a heavy duty crossmember out if it's gonna end up throwing money away
