Old 10-11-2013, 01:01 PM   #1
mi396ss
Tach Wiring Help
I have a Super Pro tach I want to put in my truck but it's older and I'm not sure how to wire it. There are red, green, black and white small gauge wires on it and I'm not sure what they are for. I know one goes to the dist but what are the rest for? Any help is appreciated.
mi396ss is offline   Reply With Quote
Old 10-11-2013, 01:28 PM   #2
bigmac73
bigmac73's Avatar
Re: Tach Wiring Help
green to dizzy, red to ignition source, black to ground and white is power for the light, should plug into your dashlight fuse source
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-11-2013, 01:31 PM   #3
john
member #16
john's Avatar
Here you go.
https://www.google.com/search?site=&....0.7Yp7o9f7YBU
john is offline   Reply With Quote
Old 10-11-2013, 01:31 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
To add to bigmac73's instruction, the green goes to the negative side of the coil if you are running a point style distributor with an external coil or the green wire goes to the "tach" lead on an HEI.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 10-11-2013, 04:47 PM   #5
88fordf150
88fordf150's Avatar
Try this.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 10-12-2013, 07:49 AM   #6
mi396ss
Thanks guys
