Old 10-12-2013, 10:04 AM   #1
sparks427
sparks427's Avatar
tryin to figure air bag management out, need help....
So i know this subject has been beat to death, but im tryin to figure out an air management system. I just want to be able to control the front and rear, i dont need all the fancy stuff where it does a hundred diffrent functions. Ive searched a ton, and find some stuff that touches on it but never seeming to find what im lookin for. There any vendors here that can put a budget kit together or somthin to just do the front bags together and the rear bags together???? Sureley this cant be that dificult.....HELP!!! Thanks in advance!!
sparks427 is offline   Reply With Quote
Old 10-13-2013, 11:37 AM   #2
67ctener
67ctener's Avatar
Re: tryin to figure air bag management out, need help....
I think most don't recommend 2 switches in the event you blow a bag. Below are two from azproperformance.com
http://www.azproperformance.com/1-4-...ement-Kit.html
http://www.azproperformance.com/Pro1...t-200-PSI.html
Talk with Travis, there also a supporting board vendor and is very knowledgable
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 10-13-2013, 11:51 AM   #3
t300
+1 on calling Travis @ azproperformance. After weeks of 'research' I wasn't sure on what I needed either, had a good conversation with him and he hooked me up. I went with a basic manual system and SS7 bags. Works great, I rarely touch it.
t300 is offline   Reply With Quote
Old 10-13-2013, 12:01 PM   #4
70blackfish
go with manual, no solenoids ...
this is what i used.
http://www.ebay.com/itm/AirRide-Susp...3baf40&vxp=mtr
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 10-13-2013, 12:22 PM   #5
mixermike
mixermike's Avatar
X2 I used the same set up, very happy with it...I wanted very simple and reliable
mixermike is offline   Reply With Quote
Old 10-13-2013, 03:19 PM   #6
muckyp
muckyp's Avatar
I used a very similar guage and toggle switch setup and it works fine. How do you guys run your lines into the cab?
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 10-13-2013, 08:23 PM   #7
sparks427
sparks427's Avatar
Ok, so with with the manual kits, or any kits for that matter, how do u know ur at the proper ride height? And im also curious as to how ya route the lines into the cab? Im definetly not opposed to the manual setup because of less electronics.
Old 10-13-2013, 08:40 PM   #8
mixermike
mixermike's Avatar
I ran my lines into the cab at the transmission hump because my control panel is incorporated in a home made console.
Old 10-14-2013, 01:15 AM   #9
BurlyCrew
http://www.littlelarrys.net/
BurlyCrew is offline   Reply With Quote
Old 10-17-2013, 08:43 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You guys that have these, do they fill the bags as fast as the ad claims? I figured they would work fine. Just curious.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-17-2013, 09:31 PM   #11
mixermike
mixermike's Avatar
I think they work faster than advertised ...I'm goin on a year now with this setup and no issues at all. Still happy and Boris aka ( way2lo2 ) is a good guy to do business with. I bought my tank, compressor, pressure switch and lowering blocks from him. Good customer service
