Tranny Bullets
My speedo is leaking tranny fluid! Mr Tran hooked me up with a bullet for my 4 speed Muncie, but it looks like it is to small cause they used blue sealant all around it and now it leaks!
Does any one know where I can get another bullet for my Tranny? Local part stores don't have em! ![]() ![]() ![]() |
What is a bullet?
Jim |
connects the speedo cable to the inside of the tranny!
They called em bullets at Mr Trany(Moron rip off Ba5T@#DS) ![]() |
67-72 Addict!
Everybody calls them bullets. Check another tranny shop!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Weapons Of Construction
Transtar
www.transtarindustries.com They'll have what you need, good prices, and may even have a store close enough to you. Good Luck!
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
I don't have the part number handy but you can still get them from your local Chevy/GMC dealer for a decent price. It is the same unit used on a TH350 automatic.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
Get it from the dealer,the one they sell is an improved version from the old aluminum ones that the plastic speedo drive used to chew up.The one that they will sell you is made of steel.HF
