![]() Join Date: Jan 2002
4x4 frames
what is the difference between 1/2 ton and 3/4 ton 4x4 frames,thanks
![]() Join Date: Feb 2001
pretty sure there is no difference............i can be wrong tho.
Post Whore
![]() Join Date: Feb 2000
The section modulus number is slightly different between some 1/2 ton and 3/4 ton frames. I believe that has to do with the elasticity of the steel. In the real world I doubt that makes any noticeable difference.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
thanks, just wondering if I could swap out everything from 3/4 ton to 1/2 ton 4x4
Post Whore
Yep, as far as I know everthing should be fine.
#6 | |
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
My cousin's C-20 frame is thicker than my c-10 shortbed. It also has a few more small corner braces on his frame crossmembers and trailing arms than mine.
