ls swap into my c10 finally
Finally found a deal on a nice 5.7 ls1 backed with a t56 6 speed manual trans in a 2000 camaro. In the process of making the deal now but im going to go for it. I test drove the car today and he is going to pull the engine trans wiring clutch parts and whatever else I may need. He prefers to pull it himself which saves me a bit of work. He says he will label everything as he goes. Anything else I should have him save me off the car that will help me? And is there a good place to get most of my ls swap parts that I will need to install it into my 69 chevy shortbox.
1969 shortbed c/10 1998 GMC sierra |
![]() Join Date: Jan 2007
Re: ls swap into my c10 finally
off the top of my head...(depending on your build) I'm not sure the camaro has all this
computers, tac module/pedal assembly, gas tank and pump/sender, gauges, possible fuse box, driveline?, shifter, hopefully, you'll get the alternator, a/c compressor, ps pump, starter, exhaust manifolds and the beginning of the down pipes including the front o2 sensors. depending on your state, perhaps the cats/etc. Rememb3r, all the extra stuff ADDS UP!!! Good luck, Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
I have an LS sitting in my garage just waiting for space to do the swap. If you do yours, maybe I'll get motivated enough to do more than look at mine.
![]() Remember, if you're questioning the harness, you can always pick up an aftermarket harness for about $400-$600 depending on manufacturer.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
I kind of switched this thread to the lsx section of the forum now. He has decided to not remove the engine and trans now so i will hopefully be picking up the whole car next weekend. Very much looking forward to this build. I have wanted to do this for some time now. I will be trying to use as much as i can off of the car.
