Old 10-13-2013, 11:43 AM   #1
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Any idea what these are??
These were in a box along with a lot of other stuff we traded for, and I have no clue as to what they are. I am not even sure they are for our trucks, may have just got thrown in to fill up space. Any ideas??? Thanks, Fred.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 10-13-2013, 12:17 PM   #2
vidman
vidman's Avatar
Re: Any idea what these are??
Cables to keep your motor from jumping around when your motor mounts break. most went from the frame to the head or manifold
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 10-13-2013, 12:36 PM   #3
specialtyretail
I was leaning that direction, just was not sure. Thanks, Fred.
Old 10-13-2013, 12:54 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Just what Vid said they were recall repair on both cars and trucks in the 60s and early 70s. Motor mounts didn't have the lock built in to keep them from jumping to far and jamming tht throttle linkage
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-13-2013, 01:03 PM   #5
specialtyretail
So, where they just used on the left hand side or installed in paies? Is this a complete set? Thanks, Fred.
Old 10-13-2013, 01:07 PM   #6
cdowns
cdowns's Avatar
they were issued in pairs alot of dealers ignored the passenger side ones tho but got paid for installing both
Old 10-13-2013, 07:33 PM   #7
CC69Rat
CC69Rat's Avatar
A friend of mine had a 69 Camaro that had them on it. I'm not sure on the rarity of them but this makes two times I have seen them personally. A lot probably got trashed / never reinstalled over the years. They would be neat to have for a 100 point concourse restoration project.
CC69Rat is offline   Reply With Quote
Old 10-13-2013, 08:55 PM   #8
tlcrz1972
tlcrz1972's Avatar
I have 2 or 3 of them, if interested I'm willing to sell them.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 10-14-2013, 12:10 PM   #9
Richardwa
Active Member
Never seen those before, I always made my own with a couple pieces of chain.
Years ago I learned you just ain't had fun till the throttle on a 70 Roadrunner with a 440 sticks due to broke motor mount!!
Richardwa is offline   Reply With Quote
Old 10-14-2013, 12:43 PM   #10
Patina'd_402
Patina'd_402's Avatar
So,... I might be chaining down the 402....
'70/C10/402/TH400.
Patina'd_402 is offline   Reply With Quote
Old 10-14-2013, 12:56 PM   #11
BrianG
BrianG's Avatar
My Dad had a 68 much before I was ever a thought. He tells about when the motor mounts had broke and he would then get on it good from a stopside. Well, the motor would rotate which somehow caused the throttle to stick side open. It would lay two nice black lines for quite a while until somehow he could get the throttle unstuck or slam it into neutral I guess.
BrianG is offline   Reply With Quote
Old 10-14-2013, 12:58 PM   #12
BrianG
BrianG's Avatar
My Dad had a 68 Camaro much before I was ever a thought. He tells about when the motor mounts had broke and he would then get on it good from a stop. Well, the motor would rotate which somehow caused the throttle to stick wide open. It would lay two nice black lines for quite a while until somehow he could get the throttle unstuck or slam it into neutral I guess.
Old 10-14-2013, 06:23 PM   #13
CC69Rat
CC69Rat's Avatar
I had an 80 Firebird years ago with a crazy built 383 in it. I got the throttle stuck in that car once, scared me pretty bad. I was maybe 18-19yrs old. I just threw it in neutral and shut it down. Not much else you can do. I coasted to a stop, unstuck it and it fired back up. Never had a problem with it other than the small stain on the seat.
Old 10-14-2013, 09:41 PM   #14
69SCSS
69SCSS's Avatar
Had to do something similar on my '66 Mustang I used to race. Strap went from a bolt on the block to a bolt on the frame side of the bracket. I did that when I broke the mount at Sears Point at the drags, pulled the fuel line right out of the fuel pump, and make it 1/2 way down the track before it stalled. had to get towed off the track! The air cleaner stud nailed the hood enough to where there was a good sized dimple in the hood you could see from the outside!!! This was a 400+hp 302 so you can imagine how hard that hit the hood! Needless to say my drive home from Sears Point to Scott's Valley was slow and very LONG!!! i installed the strap the next day.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 10-14-2013, 10:04 PM   #15
Patina'd_402
Kinda happy I have these...
'70/C10/402/TH400.
