Old 10-13-2013, 05:25 PM   #1
chevy1970c10
my 70 swb build
rust removal begins as usual, floors, inner and outer rockers, cab corners, kick panel, front floor brace
chevy1970c10 is offline   Reply With Quote
Old 10-13-2013, 05:27 PM   #2
chevy1970c10
Re: my 70 swb build
some more pics. with alot of help from brother pulled left fender, hood and pulled bed off.
Old 10-13-2013, 05:28 PM   #3
chevy1970c10
Re: my 70 swb build
the truck before I started rust repair.
Old 10-15-2013, 01:38 AM   #4
chevy1970c10
Re: my 70 swb build
today fit inner rocker panel
Old 10-15-2013, 11:10 AM   #5
mcbassin
Still Learning
mcbassin's Avatar
Re: my 70 swb build
Welcome to the board! Looks like a good start on real nice truck. My favorite year too. Subscribed.
mcbassin is offline   Reply With Quote
Old 10-16-2013, 01:14 AM   #6
chevy1970c10
Re: my 70 swb build
Thank you, glad to have found this site. just cant wait to have all the rust taken care of!
Old 10-16-2013, 07:04 AM   #7
Xeen
Xeen's Avatar
Re: my 70 swb build
Welcome to the board.
Good luck on the build, I'm glad to see you are doing the metal repairs right, when you get done you will have a truck you can be proud of.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-17-2013, 10:06 PM   #8
bayarea c10
bayarea c10's Avatar
Re: my 70 swb build
where the updates
bayarea c10 is offline   Reply With Quote
Old 10-19-2013, 01:10 AM   #9
chevy1970c10
Re: my 70 swb build
plan to hit it hard this weekend!
Old 10-20-2013, 10:48 PM   #10
chevy1970c10
Re: my 70 swb build
cut out portion of front cab support and burned in new section
Old 10-20-2013, 10:52 PM   #11
chevy1970c10
Re: my 70 swb build
burned in inner rocker, lower A-pillar, kick panel, rear pillar and cab corner and realized I hate patch panels!!!! these replacement panels barely resemble the original metal and require a ton of work to fit correctly! all that's left is fitting outer rocker and lining up with door and fender.
Old 10-20-2013, 10:53 PM   #12
chevy1970c10
Re: my 70 swb build
one more pic
Old 10-21-2013, 12:34 AM   #13
JD'S 69
JD'S 69's Avatar
Re: my 70 swb build
Welcome to the board. Are you planning any other work on the truck.
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me"
My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095
JD'S 69 is offline   Reply With Quote
Old 10-21-2013, 01:22 AM   #14
chevy1970c10
Re: my 70 swb build
plan is to repair all the rust first, cpp c-notch, disc brake front and back, 4/6 drop and 20" boss wheels to start, then body work paint and interior and finally 383 stroker.
Old 10-22-2013, 02:20 AM   #15
chevy1970c10
Re: my 70 swb build
well CPP SOS grand slam big brake front and back kit ordered tonight had to take advantage of the Free shipping saved me bunch of $$$. wasn't really ready for it but had to save some dough. next up wheels and tires
Old 10-28-2013, 12:40 AM   #16
chevy1970c10
Re: my 70 swb build
cut out rusted out drivers side floor section and burned in new patch panel, also began fitting rocker panel and had to fight with fit up front so ran out of time to get it burned in. removed bump stop's in preparation for c-notch
Old 10-28-2013, 12:42 AM   #17
chevy1970c10
Re: my 70 swb build
the weird looking paint on floor is because I bought clear por-15 and painted over it before it was dry so top coat cracked will have to scuff down and respray
Old 10-28-2013, 08:40 AM   #18
mcbassin
Still Learning
mcbassin's Avatar
Re: my 70 swb build
Very good progress on the floor panel.
Old 11-05-2013, 03:11 AM   #19
chevy1970c10
Re: my 70 swb build
made some progress this weekend, finished up drivers side rocker finally and started on passenger side. had major fitment issues with rocker and almost just threw it out!
Old 11-16-2013, 06:03 PM   #20
chevy1970c10
Re: my 70 swb build
got some stuff in mail today,
cpp 13" big brake grand slam kit front and back, now need new wheels before i can start.
Old 11-16-2013, 11:31 PM   #21
chevy1970c10
Re: my 70 swb build
Started on passengers rocker drilled off all spot welds and pulled rocker off in one peice have some work to do as you can see.
Old 11-25-2013, 12:44 AM   #22
chevy1970c10
Re: my 70 swb build
cut out all the cancer on passenger side
Old 11-25-2013, 11:06 AM   #23
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: my 70 swb build
Very Good metal work, I like it.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 12-09-2013, 01:34 AM   #24
chevy1970c10
Re: my 70 swb build
got some work done in cold today, a-pillar, rear door lower pillar & cab corner
Old 12-09-2013, 01:36 AM   #25
chevy1970c10
Re: my 70 swb build
Thanks Mr Chevrolet.
