1967 Chevy C10 Automatic Floor Shifter
Im new to the forum and not sure if there is an existing thread on this subject. But I would like to install a floor shifter for my TH350 which is hooked up to my 350 motor. The column shifter that is currently present is a bit awkward. A floor shift with a ratchet option would be much more conveinient. Any suggestions as to feasability, installation and brand of shifter would be appreciated. I'm currently looking at the B&M line. Again, any help with this project would be greatly appreciated.
![]() Join Date: Jan 2012
Chaozen , great looking tuck . welcome to the site . i had a 72 gmc that the previous owner had put a b & m truck mega shifter in and it worked well .
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
![]() Join Date: Feb 2002
Re: 1967 Chevy C10 Automatic Floor Shifter
I had a '67 K/10 Suburban with a 454 and a TH350/NP205.
It had a B&M Megashifter left over from the PO. When a greasejockey at a JiffyLube jammed it I replaced it with a Hurst V-Matic. They're both about the same, just don't let idiots anywhere near your controls.
JRods Garage
Lokar makes some pretty nice floor shifters too!
I am a Referee of life.
If you're running a bench seat make sure you specify that.Some shifters are short and/or set just right to hit the seat.I guess with buckets you would have room but it may also be in an awkward spot.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I had installed a mega shifter in an old jeep I had. Its a pretty straigtforward process and the instructions are fairly easy to understand, but Im sure there are plenty of youtube videos showing how to install them.
But in our trucks I just dont think they look right unless you go with bucket seats and a custom made console with the megashifter installed in that. B&M does make a unimatic shifter that is also very straightforward with the install and looks much more like a stock shifter in our trucks. Plus the price point is the lowest of just about all the aftermarket shifters out there. Lokar makes the best looking shifter of all of them, but you will pay for it. Ive never installed one myself but Im sure its pretty simple. There really isnt alot to change when you go from a column shift to a floor shifter. Basically unhooking the the rod to the column shifter... Cut a hole for your floor shifter... Install brackets and linkage... place boot, or plastic cover on shifter.. .and your done. This is all just my opinion... That is whats so great about our trucks they can be made to fit so many different taste. Good luck and keep us posted
71 swb 350/4sp manual 5/7 static drop |
Thanks for the input everyone. What is the best way to cut the hole for the shifter? And when I buy the shifter I have to consider that I have a bench seat and have seen some pics of the shifter being too close to the seat to shift correctly. I thought you could place the shifter in any spot on the hump as they come with a 5 foot cable. Is this assumption correct?
69 C10-548bbc 67 Chevelle-440sbc http://www.dragtimes.com/Chevrolet-C...slip-5661.html |
Very nice interior. Where do you find the bucket seats and console arrangement?
Spend the money and get yourself a Lokar. You wont be disappointed.
![]() Join Date: Jul 2012
I'm running a bent arm 23" Gennie in mine with a 700R4. Read quite a bit about floor shifters on the HAMB and the Gennie seemed like the best option for me. I bought a removable high hump so it was pretty easy to figure out the hole placement. FYI I got the mid-mount assembly which puts it over the trans vice the tail mount which would have placed the shifter quite a ways back towards the seat.
Theres an article in a recent Custom Classic Truck mag about replacing the floor hump and using the I think Lokar shifter. The Lokar looks like the ticket to me, it mounts right to the top of the tranny. Clean design. I dont have one just chiming in my 02 cent worth.
#13 |
B&M mega shifter works great for me for the last ten years
Fuzzy |
#14 |
Thanks for the pics. That B&M Megashifter looks like it is placed just right. That shifter is on my shortlist as it looked like it would work well. Well payday is Thursday and so far the Megashifter is at the top of my list now that I see it with a bench seat.
#15 |
In several automatic cars/trucks I have had in the past I have gone with the B&M Z Gate shifter. Never had any problems. Its cable opperated, small, has seperate reverse lock out, easy to install, and you can mount it at any angle.
#16 | |
#17 |
Old member
I started out with the B&M floor shifter but bought a S-10 floor shifter and installed it. I used the B&M cable for now. When I take it into the shop for the LSx motor and trans swap I plan to have it hooked up with the right cable.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#18 |
Hey Andy,
What does the Red switch do? Salvo a string of 500 pounders?
#19 |
ejection seat?
#20 |
Old member
Locks the torque converter in are out.
#21 |
I like the Lokar line myself. they have several different designs, and lengths. I myself have purchased one, but am yet to install it as my project is far from that point. You can also look at the TCI outlaw series. they are very popular in mustangs, (5.slOws) but the make them for many applications
72 C/10, LWB, 5.7, Auto, with A/C ![]() F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" |
#22 |
i have the megashifter as well. works great.
#23 | |
#24 | |
the first thing i would do with a floor shifted auto is convert back to a column to get the stupid shifter up out of the way (waste of floor space), or better, take advantage of the hole in the floor and switch to a 6 speed. a shifter on the floor without a clutch pedal is a total kill joy for me. the 3 on the tree in my 72 Burb C20 makes more sense than an auto on the floor.....shifter is right where i can grab it AND i get the fun of working a clutch pedal. the floor auto in my 97 Camry drives me nuts (if it wasn't so close to the grave, i'd put a stick shift in it). i even accidentally shifted into reverse a couple weeks ago as i was coming down to a stop light. killed the engine, but luckily didn't hurt anything. for me, an auto on the column is safer...no tendency to play with it.....just set it and forget it! that being said, i do like the interesting consoles you guys have used to convert to a floor shifter. |
