10-14-2013, 02:08 AM | #1 |
10'' rims
Cant remember if I have asked but
Is it a given that if I run some 10'' wheels on my truck that the frame is going to split where the steering box mounts against the frame? Not going to run them long.A few months at the longest. I dont want to hurt or weld on it any.Or can I put some flat washers against the frame to keep it from splitting? Thanks guys. |
10-14-2013, 07:32 AM | #2 |
Re: 10'' rims
ive had mine on for a year or 2 and everything's fine. I didn't know that was a possibility?
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
10-14-2013, 09:17 AM | #3 |
Re: 10'' rims
My son's 87 split at the steering box. The guy at frame shop said that he has fixed alot because of the wide wheels and the frame is thin.
That was the reason I asked. I have seen where the 4X4 split at the box and saw where the people said they broke away from the frame. Thanks |
10-14-2013, 12:22 PM | #4 |
Diggin The SquareLife
Re: 10'' rims
its not cause of the wheels.....it happens a lot on these trucks
10-14-2013, 01:45 PM | #5 |
Re: 10'' rims
There are reinforcement brackets of various styles available to strengthen and or repair the area where the steering gear bolts on. It's because of the added stress in the steering area in extreme conditions like hard cornering or off road. It can happen to stock trucks used heavily not just those with bigger tires or more grip.
10-14-2013, 09:10 PM | #6 |
Re: 10'' rims
ok. that explains the thread. I had to have a reinforcement plate put on my son's 87. After reading some posts on here I thought because of the 10'' wheels and 275's on them.
I have thought about a plate on my 86 but dont really want to mess with the frame. |
10-14-2013, 09:37 PM | #7 |
Re: 10'' rims
I think one tons came from the factory with braces that run from the crossmember to the frame rails. I would look through the salvage yards for a pair of them if you have any concerns.
Frank
Born and proudly residing in a Red State ! |
10-15-2013, 01:40 AM | #8 |
Re: 10'' rims
10-15-2013, 01:55 AM | #9 |
At the body shop.
Re: 10'' rims
Said braces.
" That didnt make it any newer " " Dont antique the equipment " |
10-17-2013, 01:00 AM | #10 |
Re: 10'' rims
10-17-2013, 02:07 AM | #11 |
Re: 10'' rims
Never seen those braces in a one ton. They year specific?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-17-2013, 09:39 AM | #12 |
I know the pieces fit
Re: 10'' rims
The frames were cracking behind the steering boxes back when these trucks were new, but back then it was only on 4x4 trucks with big lifts and tires. The steering box braces have been around as long as I can remember. 10" wide wheels are not necessarily the kiss of death. It helps to keep in mind that these trucks have extremely over-boosted power steering and just because you can go lock to lock sitting still with one finger doesn't mean you should show all your friends. Cranking on the steering wheel sitting still can be worse than wheel/tire width.
10-18-2013, 02:07 AM | #13 |
Re: 10'' rims
Thanks guys. Just want to run different wheels for a while
I have some 10's and thought about them.Just different Here is the son's truck that's getting parted I think. Last edited by PAWS 72; 10-18-2013 at 02:08 AM. Reason: added thoughts |
