Old 10-14-2013, 04:50 AM   #1
hearselover
hearselover's Avatar
Extra under wheel arch fuel tank option.
My daughters truck came with 2 extra tanks under the back wheel arches in front of the wheels which we were told is a factory option, does anyone have the options list for a 67 truck just so I can see what they are all about (or am i asking for something that doesn't exist).
Cheers
Ash
hearselover is offline   Reply With Quote
Old 10-14-2013, 09:35 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Extra under wheel arch fuel tank option.
Possibly aftermarket tanks.... can you post pics?
Edit: Factory aux. would be one extra tank only.... I'm thinking yours are aftermarket b/c you say there are two.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 10-14-2013, 03:25 PM   #3
Andrew S
Factory installed tanks were probably option code NL2. They will have a filler neck through the bed-side. Aftermarket typically used a door cover, or filled from the wheel wells. These two threads should tell you quite a bit:
http://67-72chevytrucks.com/vboard/s...d.php?t=571256
http://67-72chevytrucks.com/vboard/s...d.php?t=560607
'72 K20
Andrew S is offline   Reply With Quote
Old 10-14-2013, 05:20 PM   #4
Lee H
Lee H's Avatar
Sounds like dealer installed saddle tanks. Can you post a picture of the bedside fuel door?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-14-2013, 09:19 PM   #5
Prematuregrey
Prematuregrey's Avatar
They are more than likely dealer installed aftermarket tanks. I just had mine out to clean and re-coat the exterior with Rust-o-leum rubber coating and redo the tubing/hoses so I may be able to answer some questions for ya. Do they look similar to these? Mine have aluminum doors in front of the rear tires.
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline   Reply With Quote
Old 10-15-2013, 04:45 PM   #6
hearselover
Sorry for the quality but this is the only pic ive got of the tank, the weather here is awful at the moment and the Truck is tucked away safe.
Cheers
Ash
Old 10-15-2013, 05:05 PM   #7
jocko
jocko's Avatar
Shown is the rear face of dealer-installed or owner-installed aftermarket dual saddle tanks. They are nice ones because they have the wheelwell filler neck, eliminating the need for the aluminum bedside filler doors. Have the same tanks on my 71.
