10-14-2013, 01:20 PM | #1 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
Shorty Headers!!! FLOP!!!
Put Shorty Headers on my 84 and every time I turn around one of the Nuts have backed off!!! I have tried all sorts of methods to secure them but it doesn't work!!!! What headers have U found to be the best, etc.!
10-14-2013, 02:43 PM | #2 |
Parts and more parts
Re: Shorty Headers!!! FLOP!!!
For the header nut issues. Try putting teflon tape on the header bolts and then tighten the nuts up snug. Start the truck and warm the pipes up to operating temp and check the tightness one more time. It works, the teflon tape will keep the bolts from backing out and the nuts will stay tight. once set, they stay until you loosen them. If it is on bolts that the Y pipes mount to, then double nut them to have them stay.
Frank |
10-14-2013, 03:42 PM | #3 |
My headers did the same when I bought the truck. First thing I did was replaced the bolts and used nyloc nuts. Also I re-hung the exhaust with flexible hangers. The po had the pipes and muffler secured almost solid with no flex. Pipes wouldn't move but motor did and loosened the collector bolts quickly. Been good since. Here's a link for nyloc nuts.
http://en.wikipedia.org/wiki/Nyloc_nut |
10-14-2013, 05:37 PM | #4 |
Use header lock washers. Not normal lock washers. You can use red silicone on the threads and let it dry. This method has always worked for me
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-14-2013, 08:56 PM | #5 | |
Stage 8 locking fasteners are the way to go. Studs and nuts don't work in most cases because of clearance issues. Header bolts have smaller heads for a reason.....
http://www.stage8.com/gm.html
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-14-2013, 09:05 PM | #6 |
My problem is at the Collector, pipe to header area.
10-14-2013, 09:08 PM | #7 | |
Long Hair, I see them thanks!!!
10-14-2013, 09:56 PM | #8 |
Pinch lock bolts with lock washers are the stuff to use here
