I had the windshield replaced in my 70 c10, the first time i used a lmc gasket with chrome channel,after the windshield leaked i used a precision gasket and it still leaks only not as bad. the winshield was a fy not a ppg. any suggestions?
Re: leak
I would look real close at the drip rail (on the roof )for cracks that will let water in as it runs down the in side of the glass.
(from the been there done that)
Trueman |
Re: leak
Welcome to the forum. Have you located the exact entry point of the leak?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: leak
The windsheild was fy not a PPG? I assume you mean something like Tong Yang[Large importer company for those of you that are not up on parts slang]. I have used windsheilds from a local place in Little Rock AR called Discount auto glass and they sell imported glass[ I buy a windsheild for a 99-07 chevy truck for $65 bucks or $150 installed if I don't have time]and I have never had a fitment problem with the glass. Now I am surely not saying that you couldn't have an issue with a bad glass, I am saying out of the hundreds yes in the hundreds I have used I have not had an issue with that being a problem. Have you been able to pinpoint where the leak is coming from? Is it coming between the rubber and the glass or some where else? Jim
Re: leak
Easiest way is using water hose on a trickle with someone in the cab looking for the leak. May even require removing wipers n cowl using the same method.
Common spots to leak is in the two upper corners, and antenna wire feed into the cab. More serious areas are the in the upper drip rail or the area around the windshield lip. I like using a seal from the manufacture that made the glass and had the best luck that way.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: leak
Double posted for unknown reason
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 10-14-2013 at 06:01 PM. Reason: Double posted! |
Re: leak
,the leak appears to be between the channel and the gasket,not the glass and the gasket
#8 | |
Tech Help
![]() Join Date: Apr 2012
Re: leak
http://youtu.be/SOU_0HpS7To Thanks Derek
PRECISION Updates Subscribe --->Installation Videos Follow ------->Instagram Like---------->Facebook |
#9 | |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Re: leak
Excellent video. Many useful hints there. I have a problem with my truck leaking. PM sent.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#10 | |
Re: leak
Re: leak
The original assembly manual for these trucks recommends the use of a sealer between the rubber gasket and metal channel on both upper corners. If you don't do this, chances are good that it will leak.
