69 seat?
Is this what the 69 fuld forward seat looks like?
Is the 69 seat different from a 72 seat in any way besides the fact that it folds forward?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: 69 seat?
I don't think '69 bench seats fold forward. Mine doesn't and it looks different than that anyway, and I'm pretty sure it is stock
Re: 69 seat?
I understand one year the seats folded forward, not sure what year but this truck is suppose to be a 69..
Anybody else?? Thanks!!
Re: 69 seat?
I also need to know if the brand new seat cover i bought for my 72 will fit on this frame if i do buy it..
![]() Join Date: Jan 2012
Swamp Rat , i had a 72 GMC and it had a folding bench seat in it .
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
Re: 69 seat?
That is a '67 seat. Looks exactly like mine. Only '67 seats fold forward maybe some early '68s as reported by members here. The fixed seat back was part of a federal safety regulation that also included : no more "small back window" and added mandatory side markers front and rear.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Re: 69 seat?
There is something different with seat foam and covers between years. Not sure what exactly. Member "truckseats" could tell you for sure or even make a 72 style cover made to fit a 67 seat.
![]() Join Date: Apr 2013
Re: 69 seat?
That is most likely a '67 seat, that folds forward.
Now I converted my '72 seat to fold forward using parts from a '67 seat. The differences are in the pivot location/front bolt (on the fixed seats). And the foams are all the same shape.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
Re: 69 seat?
Thanks for the help guys, i can pick this seat up for $75, and actually the cover isn't ripped but its a recover and i have no idea if the foam is stock but it feels pretty soft. I figure if this is a 69 truck the owner swapped it out for the 67.
I was debating getting it even if i cant use it as i hear there sought after for people wanting to remove the cab gas tank, but if i can make my seat fold i may just do it!
Re: 69 seat?
Did you document how you modded your seat?? pictures?
![]() Join Date: Jul 2007
Re: 69 seat?
I have a 72 and the seat does not fold forward. Sure wish it did though as I am always wanting to get in behind the seat for something.
72 chevy 3/4 ton 4X4 |
#12 | |
![]() Join Date: Aug 2008
Re: 69 seat?
When i installed the new cover on the seat, i modified the cover to not cover the upper attachment arms. When reassembling it, i installed the two bolts back into the lower without threading them through the upper and let the upper arms rest on the bolts. I have yet to drive the truck nmuch but well see how it works out. |
#13 |
Re: 69 seat?
No I didn't, I'll have to go look and see.
My seat is a full foam seat, and the '67 seat back was springs, so just swapping back frames wasn't an option. (plus there were some other differences that I don't remember). But if I recall correctly I did some measuring first to see how much the location difference was between the tilt pivot and non-tilt bolt holes. I cut the lower arms off of long off of the 67 seat, so I could grind to fit. Then I removed the cover, drilled holes in my '72 seat base where needed then I bolted the '72 seat frame back together. Then positioned the cut arms where the new pivot holes were to be and cut and ground till the cut was located in an acceptable place. Then I scribed on the '72 frame where to cut the back frame arms off at. Cut them off and then cleaned the area to be welded, jigged it up and tack welded it, re-installed for proper fitment and then finished welding. Then made angle plates to weld to the frame to stop the seat from going back to far and welded it in place.
#14 |
Re: 69 seat?
Interesting mod for sure!
