Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-14-2013, 07:45 PM   #1
Pro Performance
Pro Performance's Avatar
New! 14" Baer Big Brake Kit - $999
New - 14" Big Brake Kit - $999
We have been working with Baer on a new brake kit for the C10's, which will be exclusively only through Pro Performance. This new brake kit will work with any factory disc brake spindle or factory style disc brake drop spindle, such as McGaughys, Early Classic, BellTech, etc. We feel this is an important feature of the brake system, because it doesn't require you to change spindles, and can use what you already have. You will receive a template and instructions on modifying your spindle, which requires cutting of the caliper "ears" and drilling and tapping for the caliper mounting bracket.
Note: Photos shown are preliminary mock up photos, 6-lug is not available. Only available in 5-lug.
Key Features:
1) No need to buy new spindles, just modify current spindles
2) Uses new calipers, not rebuilt
3) Precise machined hub
4) Laser cut mounting bracket
5) Fits in most 18" wheels and larger
6) Will work with most aftermarket wheels, since caliper offset is kept to a minimum.
Kit Includes:
- C5 Caliper - New (Not Rebuilt)
- 14" 1-Pc. Rotor, Drilled / Slotted with Directional Vanes (1.1" Thick)
- Machined Aluminum Hub - 5x5 Bolt Pattern
- Caliper Mounting Bracket
- All Necessary Hardware
- Brake Pads
Pro Performance is offline
Old 10-22-2013, 11:15 AM   #2
Pro Performance
Re: New! 14" Baer Big Brake Kit - $999
Just wanted to let everyone know, that a matching rear 13" kit is already in the works.
Old 10-24-2013, 01:15 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Any info on the rear kit? Built in ebrake or not?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 10-24-2013, 11:15 AM   #4
Pro Performance
The rear kit will use a single piston caliper on a 1-piece 13" rotor. The plans are to offer it both ways, with an integrated e-brake on the caliper & without.
Old 11-22-2013, 01:52 PM   #5
Pro Performance
Got this new kit uploaded to the site:
http://www.azproperformance.com/Baer...60-87-C10.html
Old 01-21-2014, 06:08 PM   #6
Pro Performance
A shot of the calipers that a board member painted red.
Old 02-27-2014, 04:26 PM   #7
Pro Performance
The rear kit will be ready to ship early next week. We designed the rear kit so that no machining to the axle or rotor is required, since we actually use a truck rotor.
Photo of the front kit installed.
Old 02-28-2014, 10:47 AM   #8
greystoke
I may be interested in a rear kit. I'm building a 59 GMC so I'm thinking of getting a 88-98 rear end, would the rear setup work?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline
Old 02-28-2014, 03:02 PM   #9
Pro Performance
This particular rear setup will not work because the axle housing flanges are different on the 88-98 axle. We will be working on the 88-98 in the future, but no ETA yet, and may be towards the end of the year.
Old 12-17-2015, 02:08 PM   #10
Pro Performance
I have now created a tech install article for the front and rear, so you can better see the steps to install this front kit.
Front:
http://www.azproperformance.com/14-R...all-Front.html
Rear:
http://www.azproperformance.com/14-R...tall-Rear.html
Old 12-17-2015, 02:53 PM   #11
Advanced Design
Advanced Design's Avatar
Good articles Travis. They are well documented with photographs with good explanations. The one item not covered was hooking up the rear parking brake. Will you be covering that?
Also, my 72 Suburban could use an upgrade. Would you recommend this system or perhaps another? It is a 3/4 ton and the previous owner installed drop spindles for a 1/2 ton by machining the ball joint tapered hole to fit. I haven't verified that yet with a visual inspection myself. Guessing I could verify what the spindle is, determine if the rear end / axles are correct for this application and move forward from there. With the 20 inch wheels it has more go than whoa.
Appreciate your thoughts.
Advanced Design is offline
Old 12-17-2015, 03:08 PM   #12
Pro Performance
Thank you. I have never really written anything like that before, so glad to hear the great feedback. We added the e-brake cables after we installed that kit, so I will be adding those next week. I will be installing them on my dad's truck during the Xmas holiday.
This kit is a good blend of performance and price. I think it will be a good fit for your setup, considering you have the dust shields bolt holes, and is a drop spindle for a 1.25" thick rotor. Assuming he used a 71-72 spindle and not a 73-87 that had a chance of being a 1.00" rotor version.
Let me know what you find out on the spindle and rear. If the rear was changed to a 1/2T rear, then more than likely it will be good. There are some older ones that had the press-on backing plate.
Old 12-17-2015, 08:41 PM   #13
Jon01
Jon01's Avatar
Any chance at hi-fi caliper upgrades - C6Z, CTSV, etc...?
Jon01 is offline
Old 12-18-2015, 05:53 AM   #14
Advanced Design
Thank you Travis. I will determine what I actually have at some point in time...lotta project irons in the fire.
Old 12-18-2015, 11:15 AM   #15
Pro Performance
Not at the moment. Once we change to a Z06 caliper, it closes the price gap difference, from going to a Baer T4 caliper, which would be on par with the Z06 caliper. We might look at it in the future.
Closed Thread
