The Waco Kid
GM Performance Parts Serpentine Belt Drive
GMPP serpentine belt drive kit part #12497697. This kit had the brackets mocked up, then removed and sent off for powder coating. None of the other parts have been used and are still new in the boxes. I have a couple extra pieces that will be included, a reverse rotation fan that has been powder coated black, and an extra left engine bracket. The extra bracket is used, but does not have the space for the smog pump so it has a little cleaner look over all. However, the powder coating on that piece did not come out as well as the others, it is grey like the others, but has a slight reddish tint to it. I don't think it would be a problem once it's installed if you decide to even use it. This is the kit with out A/C, if you want A/C simply add the compressor. $450 shipped
Here is a link to this kit at Summit, their price is $629: http://www.summitracing.com/parts/na...7697/overview/ Thanks, Greg |
The Waco Kid
Re: GM Performance Parts Serpentine Belt Drive
Aaa
Will it work with a big block
![]() Join Date: Oct 2012
Interested in any trades?
The Waco Kid
70ptta, small block only
tjmeadows, not really, unless you have some LS swap stuff. Thanks, Greg |
The Waco Kid
Bump
The Waco Kid
Ttt
![]() Join Date: Dec 2011
Curious, is there a dummy pulley/bracket where the AC would be? Good deal by the way.
I will take it. What would the pick up price be and how do you want to be paid?
If you ask the question. Make sure you are ready for the answer. 69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171 |
I just saw that this is the metal kit for up to 86. I am looking for the aluminum kit which is what the guys at Old Air said the Sanden compressor will fit. They said if I wanted to go with the serpentine set up because the conversion bracket they have only works with the aluminum bracket. Do you happen to know what the difference between the metal and aluminum bracket is?
Would you do 400 shipped ?
Bret ![]() Here's a link to my build http://67-72chevytrucks.com/vboard/s...d.php?t=577889 |
The Waco Kid
twouvakind, yes, there is a dummy pulley that mounts in place of the A/C compressor.
TazmanB, this is the aluminum bracket set, the metal bracket set was used from 88 to about 92, after that they were this style. Sending PM with contact info. bertvert72, I can't go that low. |
#13 |
okay I'll do 450 shipped . I'll take it
#14 |
The Waco Kid
Sold to TasmanB
#15 |
Good meeting you Greg. Thanks for a good deal on some nice parts.
