Welding up larger holes...
Hello All, just getting in from several hours of welding and grinding, not fun at all. Im working on some trouble spots on the floor of my 58. I noticed that there are additional holes in the floor, presumably from former owners who may have had different seats in it. Judgung from the molestation in the floor (that I just fixed), there may even have been bucket seat in it in the past! Anyway, some of the holes are pretty decent sixed, maybe approaching 1/2" wide, though I think they a bit smaller. THey seem a little too large just to weld up. In these cases do I need to cut out some plugs using sheet metal to close them up? Any ideas would be helpful.
Mark |
Re: Welding up larger holes...
maybe use a copper spoon underneath and just weld away?
I'd probably use a washer in there to reduce the amount of wire. I have a 1" thick block of steel I'd put against the washer to keep everything flush and to weld against. Just have to watch the temps or the welds start to penetrate the block.
A washer with a magnet on the backside works well, just sand off any coating the washer may have on it cad, zinc, ect.
^^^^ Good point! No Zinc / Cad!
Some outfit actually sells an assortment of plugs for doing just that but I'd either do the washer on the back thing or cut a plug out of a piece of scrap.
I bought a copper welding spoon similar to one of these http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40 a while back but haven't tried it out yet. They act as a heat sink and the weld doesn't stick to them. Don't get carried away trying to fill the holes too fast and weld a bit and let it cool and weld a bit more rather than trying to weld up the whole hole at one time.
$8 welding spoon at Harbor freight, I've have one also, but so far every hole I,ve welded up on the firewall I couldn't reach the other side with it, would help if you had a helper on the other side.
http://www.harborfreight.com/welding...oon-66785.html When I worked at a sheet metal shop years ago, there was plenty of slugs laying around by the punch press machine. Last edited by 1958Warrior; 10-15-2013 at 01:18 AM. Reason: add |
![]() Join Date: Jul 2006
Yeah, don't breathe zinc welding fumes, you won't like how puking your guts out and feeling like death, trust me on that one!!! The last thing you want is to drink milk but that's the quick remedy. We arc welded a bunch of galvanized embeds to galvanized decking and there was zero air movement. Learned that lesson the hard way, but I suspect a couple of washers would be fine so long as you keep your face away.
For holes, I pick up electrical box knock-outs off the ground on jobsites. It has gotten me a couple of funny looks but I just tell them "they taste great". There are 1" and 1.5" or 2" circles, just use a uni-bit to make the hole larger, hold it with a magnet and voila. As an electrician you know to bring you home a couple handfuls.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
That 7.99 HF welding spoon that 1958 Warrier posted sure looks exactly like several of those 16 to 20 something ones that I posted the link to earlier. Hummm buy a basket of them at HF and double the price on Ebay.
One of the do it yourself tools at the restoration shop that The Gene Winfield metal working class I went to had. ![]() Gene welding a hole in the middle of a 57 Chevy door ![]() The weld ![]() Leevon, that reminded me, both of my brothers are journeymen electricians and I need to get them to save me a batch of those.
Thanks for all the great feedback guys. Very helpful.
If you have any plumber buds just flatten one end of some 3/4" copper pipe and that works killer plus you can make it any length you want. Great for reaching into quarter panels.
Hey 55 dude thats exactly what I did! worked great and I could bend it whatever way was needed for the particular hole. Awesome.
#13 |
This I one of those tools that hangs around forever until you lend it out.
#14 |
You can also take the copper pipe and flatten around a curve surface (pipe, socket, etc.) to use for curves. Do make sure you insulate the other end even a 12-18" length of copper can get hot fast even thru welding gloves. I have a variety of bimetal hole saws I use to cut filler for holes over 1/4". here is photo of the firewall with almost 50 holes in all sizes I filled. Odd shapes I just cut and grind with my small cutoff disc.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
