Heads
I have a stock 350 motor, I'm looking for a good pair of heads. Any suggestions? I'm trying to keep it under 500$
Re: Heads
A good budget head I've heard about is ProComp, you can find them on ebay for I've heard in the low to mid $300's already assembled just have to put them on the motor.
You can check out this link. http://www.summitracing.com/search/p...rder=Ascending
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
Re: Heads
lots to choose from for sure, I had good luck with a set of World heads, S/R or stock replacement..they come assembled with a 3-face grind, screw-in studs and either center bolt, or side bolt for your valve covers..They also are extra beefy in their castings, so if you are not looking to add weight to your rig, might not want these. I sold mine after running them for a couple of years for $200.00, I think new are around your projected budget.
Re: Heads
Vortec or double Humps...good bang for the bucks
#5 | |
Re: Heads
Vortec heads will kill all the above easily and can be had cheap too. And in then there is another way to get a good boost. A comp 266xe intake and headers will make more difference than any head will
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
| Bookmarks |
