Old 10-15-2013, 04:14 PM   #1
Malo83
Cruzzzn' Vet
Malo83's Avatar
Window Problems
Replaced my power window motors and regulators on both doors this weekend, windows go up and down quicker than before, but, windows won't stay in the front track, this would be the vent window lower extension, everything went back together as before but the window keeps jumping out in the front i'm stumped as everthing is bolted back together properly, new weatherstriping was replaced also but they don't look like the problem. any ideas??
Malo83 is offline   Reply With Quote
Old 10-15-2013, 04:26 PM   #2
J Knight
J Knight's Avatar
Re: Window Problems
Thinking back when I changed my window motor....it seems the only thing that might keep the window in the forward track would be the roller that fits in the track on the inside side of the door shell. I dont remember any adjustment in the regulator itself or adjustment in how it mounts either.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-15-2013, 05:38 PM   #3
Jonboy
Slots go on anything!
Re: Window Problems
I am pretty sure you can move the bottom section of the rear track forward to fight this.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-16-2013, 10:08 AM   #4
ChrisC10
ChrisC10's Avatar
Re: Window Problems
I just replaced the regulator and motor on my passenger side and it's doing the same thing. Mine looks like the rear track is pulling the window out of the front track toward the inside of the truck. I haven't had a chance to look at the drivers side yet to see if I have anyting tweaked on that side. Hope some one lets you know how to fix it I would like to know also! LEt me know if you get it figured out...I will do the same.
Mine also dosen't go up and down very good. I haven't replaced any of the seals or anything though. I'll be looking into doing the relay mod I think.
Good luck!!!
ChrisC10 is offline   Reply With Quote
Old 10-16-2013, 04:54 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Window Problems
I was thinking the same thing but nothing looks adjustable
Old 10-16-2013, 06:59 PM   #6
xole
xole's Avatar
Re: Window Problems
Make sure the bolt for the rear track is actually in the correct hole in the door.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 10-16-2013, 08:11 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Window Problems
there should be some ajustment in the motor mount bolts to door
slight but it's there,
seen the wrong ajustments leave cracks,open at the top when the window is closed
i'd check the play there
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-17-2013, 01:30 AM   #8
PAWS 72
PAWS 72's Avatar
Re: Window Problems
Good luck!!!
Let me know when you do. I need the correct color wires. Thanks
PAWS 72 is offline   Reply With Quote
Old 10-17-2013, 07:19 AM   #9
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Window Problems
I second this one, when the body shop painted my truck, they install both rear mounts in the wrong hole in the back side of the door. Moved to the right hole and all works great now.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 10-17-2013, 09:30 AM   #10
ChrisC10
ChrisC10's Avatar
Re: Window Problems
Anyone have a pic of the correct hole? I know my rear mount for the track had a couple washers to adjust it away from the inside of the door some.
@PAWS 72 - What wires do you need the color to?
Old 10-17-2013, 03:50 PM   #11
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Window Problems
No extra holes on my door??? only 2 holes to mount
indow trac
