10-15-2013, 04:29 PM | #1 |
removing heater
I removed the heater that was in the cab of my truck temporarily. I was wondering if I can just plug the holes in the intake manifold and the water pump with hose plugs or do I need to run a hose from the pump to the manifold? Also does running the radiator fluid through the heater cor keep the engine cooler even if the heater is turned off? I am mostly concerned with my engine running hotter.
10-16-2013, 08:50 AM | #2 |
Re: removing heater
You can plug the holes or just connect the two heater hoses together. I don't think you'll see much of a difference with the heater installed or not on the engine temp.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
