Old 10-15-2013, 05:11 PM   #1
jbassC10
Smile Best Park: Re-Assemble!! Disc/20's Pictures
Justfinished painting nearly the whole frame!
Only part I wasn't able to paint was the top of the frame: under the Cab. The Cab was the only section I left attached to the frame.
Re-ASSEMBLE time has began!!!
Rear axle swap: 69 to a newer 93 half ton. Only fabricating needed was to replace old/custom fit new "perches" for the springs to set on at an Angle where the 93 perches didn't. :-\ But we got er' done!
jbassC10 is offline   Reply With Quote
Old 10-15-2013, 05:38 PM   #2
geezer#99
geezer#99's Avatar
Re: Best Park: Re-Assemble!! Disc/20's Pictures
Looks good!!
Hope you don't need to do it twice.
Are you lowering the truck too?
Did you copy the pinion angle from the old rearend?
Old 10-16-2013, 02:39 PM   #3
jbassC10
Originally Posted by geezer#99 View Post
Looks good!!
Yeah we copied the exact pinion angle to match up! Its bolted up as we speak!
And the lowering end of the subject: Will level it out basically all due to the size of the wheels and tires. We posted them under the truck with the rear springs out and front end and took a look for an idea of lowering and man....it won't take a lot just because of the size of the wheels. lol
Old 10-16-2013, 02:48 PM   #4
geezer#99
geezer#99's Avatar
THe reason I asked was that the normal procedure is to bolt the rearend in with the axle perches loose, all the weight of the suspension and the body on, sitting on your wheels and tires just like it will be when you're fully assembled. THen you set your pinion angle, check all your measurements and tack weld the perches to the axle, tear it apart and finish weld the perches.
You might get lucky!
It might be perfect!
Just remember to check your pinion angle after it's all togethor.
Old 10-16-2013, 03:15 PM   #5
jbassC10
Hey thanks for the help!!
But were good to go! Already bolted up! we did it of course a different way, but its looking good!
Thanks for the advice though!
~Tyler
Gonna go do some work on the C10 in a little bit! Excite! Reassemble continues!
Old 10-16-2013, 03:38 PM   #6
JohnT71
looks good, put a 98 rear end under mine and had to do the same.
"There's a force in the universe that makes things happen; all you have to do is get in touch with it. Stop thinking, let things happen, and be the ball." -Ty Webb
JohnT71 is offline   Reply With Quote
20's, disc swap
