Old 10-15-2013, 07:53 PM   #1
Bulldog88
What is the cheapest way to install six lug disc brakes
What is the cheapest way to install six lug disc brakes on a 68, I want to do six lug disk all around but dont want to spend a fortune, any ideas or suggestions
Bulldog88 is offline   Reply With Quote
Old 10-15-2013, 08:04 PM   #2
Syndrome
Re: What is the cheapest way to install six lug disc brakes
What is a fortune?
http://www.ebay.com/itm/chevrolet-c1...item35c2b974f2
That is a full setup for 1050+shipping. You can upgrade to the nickle plated booster for 80 more.
1970 GMC
Syndrome is offline   Reply With Quote
Old 10-15-2013, 08:07 PM   #3
mmiddle
mmiddle's Avatar
Can you/ do you fabricate?
99 up brakes can be adapted to fit our trucks, but no kits available. you will have to turn the hub centers down to fit the rotors and re-drill the lug holes to fit modern wheel studs. Then fabricate Caliper brackets.
In a few months I will start designing and fabricating the parts to do my '70. Front and rear 99 up parts with internal parking brakes, hydro-boost and ABS.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 10-15-2013, 08:12 PM   #4
Vorcutt
Vorcutt's Avatar
Classic Performance offers a complete power 4 wheel disc conversion in 6 or 5 lug for around $1650.00 if you want slotted/drilled rotors, which looks like about the best price I've found for a new complete kit from a reputable supplier.
http://www.classicperform.com/Chevy-Truck.htm#2
Vorcutt is offline   Reply With Quote
Old 10-15-2013, 08:16 PM   #5
JonCheun
Tuckers Classic Auto Parts is where I go
Tuckersparts.com
JonCheun is offline   Reply With Quote
Old 10-15-2013, 08:36 PM   #6
Syndrome
I wish tuckers would actually put a parts list of what comes with their 'kits'
1970 GMC
Old 10-15-2013, 08:39 PM   #7
DYNAMiTE
hmmmm
My truck looks like a Jig-saw puzzle.......
DYNAMiTE is offline   Reply With Quote
Old 10-15-2013, 08:57 PM   #8
ecgate
ecgate's Avatar
I did it with POL's front kit and some kit off ebay for the rear and they work just fine. I cant remember exactly but I think I had around 1000 into everything.
ecgate is offline   Reply With Quote
Old 10-15-2013, 11:10 PM   #9
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
This is how I am gonna do mine and I happen to be a dealer for them
http://www.mcgaughys.com/bigbrake.html
I believe I can also get you a 6 lug rotor for the front to fit the newer spindle ... which would be the most reasonable way to go.
The link will take you to the page with the kits on them as well as a rear kit.
ksbrktracer is offline   Reply With Quote
Old 10-15-2013, 11:43 PM   #10
Syndrome
No price? And all of the kits you linked to only have the 2" drop spindles, I want stock height.
1970 GMC
Old 10-16-2013, 12:05 AM   #11
woodwright
Enjoying left field
woodwright's Avatar
If you have a good local wrecking yard, get the complete front crossmember and suspension from a 73-87 1/2 ton. You should be able to swap the entire crossmember for yours. Or you can get just the spindles and calipers from a 73-87, and replace your balljoints with new ones from a 73-87. After that you'll need to purchase a set of 6 lug rotors from a company like CPP.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 10-16-2013, 12:10 AM   #12
ksbrktracer
TNT-MOTORSPORTS
I can get you some prices tomorrow .... All of the catalogs are at the shop. You could possibly do the conversion to 71-72 or 73 up and then put the 6-lug rotors on it , but they do sell a stock height disc spindle for 70 and older I believe.
EDIT:
http://www.mcgaughys.com/newproducts.html
link to stock height spindles
Old 10-16-2013, 01:52 AM   #13
WIDESIDE72
WIDESIDE72's Avatar
Not mine
http://houston.craigslist.org/pts/4120431854.html
WIDESIDE72 is offline   Reply With Quote
Old 10-16-2013, 01:53 AM   #14
WIDESIDE72
WIDESIDE72's Avatar
Not mine
http://houston.craigslist.org/pts/4004306817.html
Old 10-16-2013, 07:13 AM   #15
hugger6933
68 3/4 lower control arms with 88-98 spindles and same for the rotors and caliper. the 68 LCA will take the ball joint and your upper control arm will take the ball joint for the 88-98 upper, so the spindle is basic bolt in type deal easy as changing the ball joints. This is laid out in this site somewhere, And one of my main trucks that I used to build[I rebuild wrecks for a living at my body shop] I still have a few of these parts laying around that I've kept a hold on in case I needed them when I changed to the newer body style. Those parts ought to be dirt cheap spindles real cheap and the brake pads cheap as well so I would think that is the cheapest way to go, I plan on using this method on one of my 70 SWB builds, one is a dollar down and the other will be 5 lug. Jim
hugger6933 is offline   Reply With Quote
Old 10-16-2013, 08:25 AM   #16
70Custom10Nut
70Custom10Nut's Avatar
Truck Shop in Orange CA has kits too, that won't break the bank
70Custom10Nut is offline   Reply With Quote
Old 10-16-2013, 08:46 AM   #17
jhama78
jhama78's Avatar
Do any the manufacturers tell you what application the parts are from after you purchase the kit? I'm just wondering about it from the aspect of replacement parts in the future.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 10-16-2013, 09:12 AM   #18
70Custom10Nut
I've wondered that myself, because some day I will get around to doing this conversion. I would think that the Pads would be a standard GM product and the rotors would be from a serial numbered product line too.
Old 10-16-2013, 09:26 AM   #19
Green Hornet
I have looked at the possibility of changing at least my fronts over to six lug disc but it worries me finding replacement parts for the kits will be a PITA. It is my daily driver so if I need a set of brake pads or a caliper I want to be able to hit my local parts store rather then mail order.
69 Chevy C10 Fleetside Long box
Green Hornet is offline   Reply With Quote
Old 10-16-2013, 09:30 AM   #20
VroomVroom68
Did you check with H&H?
http://hhclassic.com/search.html?q=1968+disc
Wasn't sure what your budget was...but there's a good selection...
VroomVroom68 is offline   Reply With Quote
Old 10-16-2013, 11:27 AM   #21
Pick
Pick's Avatar
What is a fortune?
I ordered this kit last week. If anyone is interested, I'll write up a review/installation thread on it. In all honesty, I was (and still am) pretty skeptical about the quality and completeness......but decided to give it a shot to try to save a little money.
The seller also offers the same kit with stock height spindles and offers kits for fronts and rears seperately at similar savings compared to other online vendors. (however, the complete kit is definitely the best deal if everything arrives and works as-advertised.)
According to FedEx, it is supposed to arrive on Monday and then I guess I'll see how it goes from there.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 10-16-2013, 11:36 AM   #22
jocko
jocko's Avatar
I was considering this for my 66 c10. After a lit if searching, I came to the conclusion that POL's front 6 lug stock height disk kit was the best quality bang for the buck, and that sell replacement rotors to help alleviate that nagging worry about availability.
Old 10-16-2013, 11:39 AM   #23
woodwright
Enjoying left field
woodwright's Avatar
The six lug rotors that fit the 73-87 spindles are not oem, as far as I've been able to find. But everything else is.
Clint
Old 10-16-2013, 02:04 PM   #24
mmiddle
mmiddle's Avatar
The 6 lug rotors are special built and will have to be bought from the kit manufacurer. Generally the front calipers are 73-87 GM truck, The rear calipers are(I believe) mid 70-80's Lincoln.
This is why I'm working on a system using the 99 up GM truck brakes. Current production parts and known standardization = simplicity and servicability.
Mark
Jesus is the Way!
Old 10-16-2013, 02:20 PM   #25
Bulldog88
So what will work for the rear? Besides the kits you have to buy and 99and up stuff
