10-15-2013, 08:34 PM | #1 |
73 350 cid engine timing
what is the timing supposed to be set at for a 350 csb?
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
10-15-2013, 08:38 PM | #2 |
Re: 73 350 cid engine timing
Stock setting is 8 degrees iirc
10-15-2013, 09:48 PM | #3 |
What other mods you got?
Might need to bump it a bunch more than 8 degrees! |
10-15-2013, 11:25 PM | #4 |
its not too much, I dont think it has a cam, but not sure. it has an intake, 600cfm carb, and aftermarket headers
10-15-2013, 11:44 PM | #5 |
Set timing at 12-14 degrees. Hook your vac advance to manifold port on the carb.
10-16-2013, 12:19 AM | #6 |
I am more or less going to try and time it and just see what the sweet spot is, its not like its already out of time but I kinda just want to mess around with it, and I think the vac advance is already in the carb port but not sure
10-16-2013, 09:37 AM | #7 |
Do you know the procedure for setting the timing?
Your carb has more than one port. Ported and manifold vacuum ports. |
10-16-2013, 10:04 AM | #8 | ||
"I ain't nobody, dork."
Only way to find the "sweet spot" is with a timing light.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-16-2013, 04:11 PM | #9 |
Yes I know the procedure, and I have a timing light
