Fabricate till you "puke"
HEI hits the freakin trash can!
Not a bad dist, but this one was "baggey" as he!! I have been looking at the MSD ready to run for a while, but the richmond trans spent the "play money " for a while. I pirated the dist from the kids wrecked ranger & dropped it in the 69. that old dist has been in several of my toys, & originally came out of a '64 283. She is a cast iron pc, tight as he!!, & been recurved & running a flyin magnet Pertronix+ coil. Talk about rock steady on the timing on a dist that has easily 150-175 thou on it! That 383 likes it! The dist pulls 24 mechanical, & set @ 10 initial is just about right. The vac can needs a little adjustment yet, but she sounds good. More firewall clearance too. tommoro i am starting on the elect fans....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
huh?
![]() Join Date: May 2000
I'm gonna have to come check that beast out next time I'm back home....maybe I can "borrow" the drivetrain?
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Do you like things that are scarey!
huh?
I look at myself in the mirror every morning, does that count as scary?
TJ that 406 sounds interesting, but after 6 gears on that stick.......I dont think I could do the 350 turbo
