Old 10-16-2013, 08:52 AM   #1
68Stepbed
68Stepbed's Avatar
Just one more.....
....inch lower in the rear. I've not been particularly pleased with the stance of my truck lately. I felt the rear just didn't sit low enough. I finally broke down and ordered a set of Hotchkis 6" rear drop springs. The ECE 5" springs have already been spoken for, but if for some reason he doesn't take them, I'll post in the classifieds.
For those that will ask, this gives me a total of 4.5" front drop and 6.75" rear drop. That's with 2.5" drop spindles and 2" drop springs in the front and 6" drop springs and 3/4" blocks in the rear.
Here's the results:
A couple of "before" shots for reference.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-16-2013, 09:41 AM   #2
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Just one more.....
Very nice, I like the look.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 10-16-2013, 09:41 AM   #3
c10Dream'n
c10Dream'n's Avatar
lookin good, did you change the tire size in the rear?
I did the same with mine, although i put 1" blocks in the rear for a total of 7". I wanted to go with an even stance versus a slight rake.
c10Dream'n is offline   Reply With Quote
Old 10-16-2013, 10:05 AM   #4
original-71
///Relaxed Atmosphere
original-71's Avatar
looks good. c-notched ?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 10-16-2013, 10:10 AM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
Always love to see your stepper Matt, beautiful truck!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-16-2013, 11:43 AM   #6
68Stepbed
68Stepbed's Avatar
Thanks, guys. No c-notch....yet, Hector. The panhard bar is hitting the exhaust, but I seem to still have enough clearance between the axle tube and frame. I'll see how bad it is after the springs settle, though. Tires are still the same.
The Hotchkis springs are rated at 380lbs. and so far they seem to have a better ride than the ECE springs. I'm not trying to say anything bad about ECE, though. They still make great products. I also need to get some correct length shocks. I'm still running stock style KYB shocks. As funds permit, I'm looking to pick up some RideTech HQ shocks.
I also just installed a new Lokar throttle pedal and cable. The stock pedal and my home brew throttle linkage was getting in a bind under heavy throttle, which could get a bit hairy in certain situations. It's not a good feeling when you lift and the truck keeps going.
Matt
Old 10-16-2013, 12:26 PM   #7
flashed
My favorite stepper ,looks great .
flashed is offline   Reply With Quote
Old 10-16-2013, 12:58 PM   #8
HSRACER
HSRACER's Avatar
Looks much better in my opinion. Very nice truck!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 10-18-2013, 07:05 PM   #9
Jon @ Hotchkis
Jon @ Hotchkis's Avatar
That is a great looking truck you got there, Matt. Glad to hear you like the coils too.
What are you going to do about the pan hard rod situation? Our rear suspension package that has the adjustable pan hard rod comes with our new Fox Racing shocks; you could kill two birds with one stone that way.
Have a good weekend.
Jon Rasmussen
Hotchkis Performance
877-466-7655 ext. 224
jrasmussen@hotchkis.net
Check out our Facebook page!
Jon @ Hotchkis is offline   Reply With Quote
Old 10-18-2013, 07:37 PM   #10
SactoJim
SactoJim's Avatar
Perfect! Best looking step around!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-18-2013, 07:40 PM   #11
BugzC10
BugzC10's Avatar
I like it..looks really good....forgot your wheel specs, but how much closer did it put your tires to the fender?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 10-18-2013, 11:33 PM   #12
67c10rustbuket
67c10rustbuket's Avatar
I always liked your truck, but now I love it! I prefer a level truck over the rake look. Perfect stance
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-21-2013, 08:54 AM   #13
68Stepbed
68Stepbed's Avatar
Thanks, Jon. As for the panhard rod, I'm not going to worry too much with it unless things get in a bind. As of now, it only bumps the exhaust tubing when it goes in a dip or high bump. I eventually have plans to build an exhaust system with mandrel bent pipes and have a buddy tig weld it all. I have looked at the Hotchkis products and like what I see. I'm just on a limited budget for now.
Basically it's 17x8- 255/50/17 front, 17x9.5- 275/55/17 rear. The fender is about 3/4" above the edge of the rear tire.
Matt
Old 10-21-2013, 09:59 AM   #14
original-71
matt i dumped my exhaust right under real axle, thats another option you may consider thinking about in the future dosent interfere with anything, just get the frame dusty if you drive on a dusty road
hector
Old 10-21-2013, 10:42 AM   #15
bbcmudtruck
That looks a whole lot better imo! Great looking truck!
bbcmudtruck is offline   Reply With Quote
Old 12-04-2013, 12:16 AM   #16
Rod Run
Rod Run's Avatar
Good looking step you have here
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 12-04-2013, 01:10 AM   #17
67_C-30
I have a radical idea!
67_C-30's Avatar
That thang would look awesome now if it was still black! -j/k
I think you nailed the look of it this time. That is about the perfect stance, IMO.
I also can relate to the linkage binding thing. My brother and I nearly died in a runaway '68 Pontiac when I was 16. That bad boy had the 350HP 400 H.O. and the motor mount broke at WOT and I didn't know it was hung until I tried to let off at nearly 90 MPH. I panicked at that age, and instead of just turning switch off, and I slammed on the brakes when it was wide open and it got sideways and spun it out off the side of the road. It has been raining, and the car was spinning so hard that it wasn't really going anywhere after it spun around a few times, and I finally got it cut off.
It gave me a new respect for non binding linkagesand having good motor mounts!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
